2001 Dakota
Old May 14, 2016 | 12:54 PM
DirtRacer23h's Avatar
DirtRacer23h
Default 2001 Dakota
Problem is that even when my truck is off and light switch is off my headlights stay on dim. as well as door locks not working interior lights not working. Pulled all grounds and cleaned them, put new battery and headlight switch in, checked all of the fuses but still cant seem to fix it. it has done this before and fixed itself but keeps coming back and seems to happen more if it rains
Old May 14, 2016 | 04:17 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum.
The headlights, door locks, interior lights, etc, all work off of the Central Timer Module. The headlight switch just triggers the CTM - it doesn't actually switch the power to the headlights.
You aren't using LED's are you? They can sometimes stay on dim.
I'm thinking your CTM is likely the culprit.
Old May 15, 2016 | 03:51 AM
DirtRacer23h
They are stock headlights. Where would I get a CTM, Junkyard or is there a place i can order a new one?
Old May 15, 2016 | 08:43 AM
00DakDan's Avatar
00DakDan
Section Moderator
You can find rebuilt units on-line. It needs to match your truck.
The keyless entry will not work after changing the CTM until reprogrammed by a dealer.
Double check all your grounds.
Old May 17, 2016 | 10:05 PM
Friar Tuck's Avatar
Friar Tuck
Inquiring minds...does it matter whether the headlights are on low or high beams?
The reason I ask is they use different driver circuits in the CTM. One may be on and the other off. Probably not, but worth checking. Might keep your battery alive.
Of course, with the other problems too, you still need a CTM.
Old May 17, 2016 | 10:53 PM
Friar Tuck's Avatar
Friar Tuck
There are 4 fuses that are important to the CTM: Two in the PDC, Fuse 3-20 Amp, and Fuse 12-20 Amp; and two in the Junction Block in the driver side of the dash, Fuse 5-20 Amp, and Fuse 11-10 Amp.
The two in the PDC are hot all the time. Make sure there is 12 Volts on both sides of each of them.
The two in the JB are hot when the Ignition Switch is in "RUN". Make sure there is 12 Volts on both sides of each of them also.
Old May 18, 2016 | 09:16 PM
DirtRacer23h
Been looking online and was wondering if the part number has to be exactly the same or not. my part number is 56045452aj but i didnt know if one that ends in AK or AM would work
Old May 19, 2016 | 08:22 AM
00DakDan's Avatar
00DakDan
Section Moderator
The numbers yes. The letters AJ, AK, etc., refer to the revision. Sometimes they are superseded. Any good seller should be able to cross reference it.
