2000 Dakota
Old Aug 8, 2017 | 02:14 PM
William H's Avatar
William H
Default 2000 Dakota
I'm having problems with my 2000 Dakota 3.9 not wanting to start when it gets up to operating temp. It turns over but won't fire. After it cools it starts and runs fine. I have replaced the crank sensor. Any other suggestions?
Old Aug 8, 2017 | 05:20 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum.
Do you have any codes? You don't need a reader.
With the truck not running turn the key to RUN, then OFF, back to RUN, OFF again, and this time leave it in RUN. Any codes will display in the odometer window. It'll show PDONE when finished.
Old Aug 8, 2017 | 06:12 PM
jetuco's Avatar
jetuco
could be ignition coil, getting heated up, then working when it cools. Coil doesnt usually give a code either.
Old Aug 8, 2017 | 08:05 PM
William H's Avatar
William H
P1391 is what originally came up when my brother in law checked it. We replaced the crankshaft sensor and it's still doing the same thing. Crank but not start when hot.
Old Aug 8, 2017 | 08:39 PM
Replace the cam position sensor as well.
Old Aug 8, 2017 | 08:52 PM
William H's Avatar
William H
I'm not sure if this motor has a cam position sensor. It's a 3.9 v6.
Old Aug 8, 2017 | 08:55 PM
It's under the distributor cap. The parts store will likely list it as "pick-up coil".
Old Aug 8, 2017 | 09:03 PM
William H's Avatar
William H
Thanks I'll check it out.
Old Aug 11, 2017 | 04:18 PM
bomrat's Avatar
bomrat
mine was the pcm..
Old Aug 12, 2017 | 09:55 AM
William H's Avatar
William H
Originally Posted by bomrat
mine was the pcm..
I don't know what a pcm is.
I replaced the pickup coil and so far it's been running and starting fine. Thanks for the help everyone.
