2002 dodge dakota 4.7L spit and sputtering and loss of power
Old 06-19-2019, 01:03 AM
Joseph Sukel's Avatar
Joseph Sukel
Joseph Sukel is offline
Default Ok
I know this is a dumb question but how do I check all of these?
  #22
Old 06-19-2019, 07:29 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,197 Likes on 2,949 Posts
Need a good scanner. (no such thing as a dumb question.)
The following users liked this post:
Goofy1 (02-19-2024)
  #23
Old 06-19-2019, 12:50 PM
Joseph Sukel
alright my buddy has one I'll see if he can help me out again
  #24
Old 06-27-2019, 06:30 PM
Joseph Sukel
Never mind he accidentally smashed it the other day so I'm buying 4 new injectors and I'm gonna throw them in
  #25
Old 06-28-2019, 01:19 AM
KDodge75's Avatar
KDodge75
KDodge75 is offline
Is it overheating?
Possibly a rocker arm fell off. I'd expect it to run rough when cold as well though if one had.
Any lifter noise?
Maybe the throttle position sensor is bad or the throttle body is malfunctioning.
Major vacuum leak possibly. Take some carb cleaner or starting fluid and spray around manifold, brake booster hose, intake hoses and anywhere else where air can be drawn into the intake. Look for cracks in plastic parts and hoses.
I came across a scanner at Wal-Mart that can read all the modules in the vehicle. It's a rebranded Autel MaxiAP AP200 called the Hyper Tough HT200. $50. Bluethooth dongle. I'll give you way more info than regular OBDII.
  #26
Old 06-28-2019, 02:57 AM
Joseph Sukel
Originally Posted by KDodge75
Is it overheating?
Any lifter noise?
Its had lifter noise on the passenger side since I bought it 2 years ago but no it doesnt run rough at all till it gets to operating temp then for some reason it shuts fuel off for fuel bank 1 (drivers side) TPS was already replaced it's always had evap codes can never find them tho even replaced the gas cap and I'll have to check that scanner out
  #27
Old 01-25-2024, 10:01 AM
McAtwell's Avatar
McAtwell
McAtwell is offline
Default What happened?
My Dodge is doing the exact same thing. I know this is a little old but did you ever find out what the problem was?
Quick Reply: 2002 dodge dakota 4.7L spit and sputtering and loss of power
