Wiper problems
Old May 16, 2021 | 04:08 PM
mcnew136's Avatar
mcnew136
Default Wiper problems
My wipers will come on with the key in the "ON" position. The control switch is off. I've tried a new control switch, a new wiper motor and tried swapping the relay out. Still doesn't fix the issue. What else could i try to fix the issue. This issue is on a 2002 Dodge Dakota SLT 4 door 4.7L 4WD.
Old May 16, 2021 | 08:48 PM
What are you driving?
Old May 17, 2021 | 04:07 PM
mcnew136's Avatar
mcnew136
2002 Dodge Dakota SLT 4 door, 4WD
Old May 17, 2021 | 04:15 PM
Moving this to 2nd Gen Dak section for ya.
Old May 18, 2021 | 08:51 PM
00DakDan's Avatar
00DakDan
Section Moderator
If you pull the relay does it still come on? Removing it will bypass the CTM and the wiper delay.
Old May 20, 2021 | 03:58 PM
mcnew136's Avatar
mcnew136
I pulled the relay under the hood. The motor wouldn't work then.
Old May 25, 2021 | 07:31 PM
00DakDan's Avatar
00DakDan
Section Moderator
Sorry, not clear.
It won't work at all? Even in low/hi?
Old May 26, 2021 | 11:06 AM
mcnew136's Avatar
mcnew136
00DakDan: They do work. While my switch/controller arm is in the "OFF" position, If i turn my key to the "ON" position the wipers start working. They won't turn off unless i pull the fuse on the inside panel or turn the truck off.
Old May 27, 2021 | 09:14 PM
00DakDan's Avatar
00DakDan
Section Moderator
OK, the park switch is in the wiper motor so that can likely be ruled out if it was doing it before you changed it.
Try disconnecting C1 on the CTM to bypass that. It's the gray connector. Then see if works ONLY with the switch in hi or low.
