Any interest here in better mpg mods?
Old Jan 15, 2022 | 01:15 AM
  #291
steve05ram360's Avatar
steve05ram360
have no idea, heads maybe $500 for the pair with cams & $100 for the intake
Old Jan 15, 2022 | 06:14 AM
  #292
V8Cowboy's Avatar
V8Cowboy
Thanks for the reply Steve, thinking about the same, gonna make him an offer, we'll see.
Found another one, complete 2011 engine with 45.000 miles, asked him for a price and if i could buy the cams only.
Old Jan 15, 2022 | 02:10 PM
  #293
Vimes's Avatar
Vimes
Originally Posted by steve05ram360
And... will the cams work on our block with the different head setup being 2 plugs per cylinder?
Twin plugs on the 5.7 is a non-issue where the cams are concerned. They will work fine on a single plug/cyl engine. The main purpose of the extra plugs is to make sure all the fuel is ignited for emissions purposes although the extra fire in the cylinder is good for a few horses.
Old Jan 15, 2022 | 02:18 PM
  #294
V8Cowboy's Avatar
V8Cowboy
Same on the 4.7L engines, but even though the heads will fit, there a few more things you'll need to change.
I just wanted the cams of a 4.7L 08+ to put in a 2000.
Old Jan 15, 2022 | 04:31 PM
  #295
steve05ram360
Tune file generated, file saved off and modified copy for fan control. Research to solve problems encountered indicates a write is not going to be successful... will find out soon...
edit: and no-go, support ticket entered. Dak is down since it erased the ecu.
Old Jan 16, 2022 | 12:41 AM
  #296
Vimes's Avatar
Vimes
Will it not reload the original tune?
Old Jan 16, 2022 | 04:35 AM
  #297
V8Cowboy's Avatar
V8Cowboy
ohhhhhh noooo......that's no good news, thought you'd be safe whenever you had the original tune and could always load this back.
Hope they can help you out, or you find a way to recover it Steve
I don't know what went wrong, and i have very little knowledge on tuning at all, but try to help, found if you go to the HP Tuner s website you could download the stock file.
Guess you already knew this but just in case
this is a youtube link,
Goodluck man
Old Jan 16, 2022 | 05:11 PM
  #298
Dodgevity's Avatar
Dodgevity
A dealer should be able to reflash it, no? Problem is getting it there. Shouldn't be more than an hour charged.
Old Jan 17, 2022 | 08:31 AM
  #299
steve05ram360
Nope, it fails at various stages...#1 - downloading the bootloader, #2 - in the middle of the write, #3 - I forget which one this is at this point I picked up my mouse pad threw it on the ground and stomped on it... <jk>
I suspect it has to do with it not finding the VIN when doing the read.
Old Jan 17, 2022 | 08:52 AM
  #300
steve05ram360
A bench flash should restore it... just need to find a shop that has the hardware & can download the file (from 3rd party) for programming.
