Water leak in heavy rain - passenger floorboard
Old 02-24-2022, 09:19 AM
Dodgevity's Avatar
Dodgevity
Dodgevity is offline
Coolant glows under UV light without dye. I had a small leak HG in cylinder 5 and was able to see the coolant when I shone a light down in it.
Old 02-24-2022, 09:38 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,269 Likes on 3,016 Posts
So the AC drain is not just for AC?
The a/c compressor also runs when you are using any variety of defrost. Refrigerated air carries less moisture. Although, so far as I am concerned, if I am running the defroster, ALL of the outside air is already refrigerated.
Old 02-24-2022, 10:17 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Had the same problem, water after rain. It turns out the frame rotted under the windshield to a poor glass installation. Had to pull the windshield, repair the sheet metal, and then reinstall.
Old 02-24-2022, 06:13 PM
ol' grouch's Avatar
ol' grouch
ol' grouch is offline
It's to drain any water that gets into the bottom of the box. Whether it's from A/C condensation or the rain collecting in the air intake. You pull air in to cool it. Anywater that gets in rolls right out too.
Old 02-24-2022, 09:12 PM
Dodgevity's Avatar
Dodgevity
I know it runs when the defrost is on. This is definitely an after the rain problem though.
Sounds like a lot of work there. Luckily, not much rusting here in GA.
Gonna pull up the carpet and run the hose soon as I get a chance. I've watched a few videos too. @HeyYou, I'll def check the back glass as I've had problems there in the past.
Quick Reply: Water leak in heavy rain - passenger floorboard
