Its the timing chain gasket ..is that very tough to change along w crank seal?
I figured that would be it. The water pump is a much smaller area but I wasn't sure if it was leaking down. Yes, it's a much bigger job than the water pump. Basically everything on the front of the engine has to come off to allow access and removal.
I see video is 3.7 ..is that the same as 3.9.on procedure?
An do these both[ that timing gasket an crank] seal off the antifreeze or just the large hoarshoe shaped one? Does crank seal block the oil.. it was hard to tell but it looked more like antifreeze than oil but I cant rule both out..
An those main gaskets,like the 2 blue ones , on my water pump look dry,the kit has those with it . .pic
Would be good if i could slide the U shaped one in but I know I should look at both ..
