Slight advance at stop
Old Apr 25, 2023 | 11:57 AM
hidden1's Avatar
hidden1
Default Slight advance at stop
I have a 01 dakota 3.9 2wd an it has a random forward advance or hesitation that only happens after sitting at a light after about 45 seconds.It never happens on short waits at lights an never in park.It isnt a everytime thing either.Ferls like truck want to move forward a tad.i replaced plugs distributor cap an rotor an the plug wires are new. I cleaned out the iac too an fuel trim readings are fine...went thru a few tanks of gas also..What else should I look at?​​​​​​​is this a timing issue? Thanks​​​​​​​
Old Apr 25, 2023 | 12:48 PM
Timing is purely computer controlled. So, not user adjustable. Did you reset the computer after the maintenance?
Old Apr 25, 2023 | 01:04 PM
hidden1's Avatar
hidden1
Ill reset it .An see what happens
Old Apr 25, 2023 | 09:59 PM
magnethead's Avatar
magnethead
do you mean it's trying to creep through the brakes?
Old Apr 25, 2023 | 10:15 PM
hidden1's Avatar
hidden1
I feel that forward arc like .. ..an slight forward move
Old Apr 27, 2023 | 03:03 AM
BCcandakota's Avatar
BCcandakota
Default Re: Slight advance at stop
I have had this happen too also a 2001 Dakota but mines a 4x4 the first time it happened I thought someone bumped into me from behind but no one there I was thinking it might be my torque converter locking up anyone have any ideas?
Old Apr 27, 2023 | 03:15 AM
hidden1's Avatar
hidden1
I reset the ecm added some seafoam to tank an so far im not noticing it..I think the reset helped..Maybe that rotor that looked a bit worn an flimsy factored it too..Ill know after more sitting in traffic .I dont know if torque conv is a factor as your sitting at a light but am curious also on it.
Old Apr 28, 2023 | 05:28 PM
hidden1's Avatar
hidden1
Did it again....random...
what next?
Old Apr 28, 2023 | 09:41 PM
Mine would do weird and strange things, but, it wasn't an engine problem, it was a trans problem.... dropping into neutral at stops, then BANGING into gear when I stepped on the gas, and various other annoying habits. Changing the trans electronics fixed mine....
Old Apr 28, 2023 | 09:49 PM
hidden1's Avatar
hidden1
Why , when it does do it, is it only after around 30 or 45 seconds? In drive fully stopped.
