Engine swap need help
Old May 9, 2024 | 12:50 AM
  #21
magnethead's Avatar
magnethead
Originally Posted by Manwithadodge
Well like I said, they kinda just lined right up which was strange, I was able to get two bolts in but not the other two
I was going to ask how you bolted them together when only 2 bolts are accessible at any given time, and that requires both starter and oil filter removed.
That aside, I'm thinking you've got a crank counterweight lodged against something in the pan. Since the dipstick won't go in either, that tells me something in the 1/2 throw.
You'll need to pull the engine back out and drop the pan again. Did you have the timing cover off by chance?
Old May 9, 2024 | 01:00 AM
  #22
Manwithadodge's Avatar
Manwithadodge
Ok cool so it might be ok? I didn't want to mess anything up so I tried to keep it assembled as much as I could the timing cover stayed on
Old May 9, 2024 | 06:30 AM
  #23
93 ragtop's Avatar
93 ragtop
I too, suspect something is jammed in the oil pan area,...... But still, as you pull the engine, I would, at each step attempt to turn it. Its a long shop, but it may save you from pulling it completely out.
Old May 9, 2024 | 03:11 PM
  #24
Manwithadodge
Alright I'll let you all know what I find
Old May 9, 2024 | 09:56 PM
  #25
Manwithadodge
So, motor is fine, now the torque converter barley wants to spin. What did I do wrong?
Old May 10, 2024 | 07:47 AM
  #26
dodgetruck2's Avatar
dodgetruck2
does the torque converter move in and out from teh flex plate or is it pinched against the motor
Old May 10, 2024 | 02:44 PM
  #27
Manwithadodge
I took the motor out completely it won't slide in or out side to side anywhere. It's like it got locked up
Old May 10, 2024 | 03:23 PM
  #28
Wonder if it got jammed up on the pump lugs.....
Old May 10, 2024 | 04:15 PM
  #29
Manwithadodge
Yep I think it did. Can you turn a 4wd trans to a 2wd.
Old May 10, 2024 | 04:34 PM
  #30
Change the overdrive housing over.
