2nd Gen Durango 2004 - 2009
Tranny cooler pictures/install info.
Old 09-17-2010, 10:39 PM
Six_Shooter's Avatar
Six_Shooter
Six_Shooter is offline
Default Tranny cooler pictures/install info.
Hello, I just bought a 2005 Dodge Dakota, yes I know this is the Durango forum, I'll get to that.
So the Dak needs a tranny a rad, because the tranny cooler in the rad blew up.
So I want to bypass the tranny cooler in the rad completly, to make sure this doesn't happen again. I was just going to pick up an aftermarket tranny cooler...
While at the wreckers today picking up my tranny, I also picked up a tranny cooler from a 2005 or 2006 Durango. It was just sitting inside on the floor, and the guy that works there, said that it was the tranny cooler, it looks the part, so I have no reason to doubt him.
Now, what I've been trying to do is find pictures of how this was installed in the Durango, so that I can hopefully install it the same way in my Dakota. I don't see how it would attach to my Dakota. Are there extra mounts that are attached to the rad support?
I know this post must make me sound new to cars, but really I'm not, I've just not owned a Dodge before, and never paid attantion to the tranny coolers when ever I've worked on these, as an Automotive Electronic Accessory Technician (used to be anyway), in other words, I install remote starters and security systems. LOL
Thanks.
Old 09-18-2010, 01:09 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
On the Gen1, the cooler sits pass side low in front of the rad.
IndyDurango
Old 09-18-2010, 09:43 AM
Six_Shooter
The 2005/2006 Durango would be a gen2 would it not?
Any pictures would really help.
Thanks.
Old 09-19-2010, 03:35 AM
IndyDurango
Yes it is a Gen2... however MINE is a Gen1 and I was just saying where IT was located.
Should be the same. Most all transmission coolers sit in the same location.
Old 09-20-2010, 07:41 AM
Six_Shooter
Ok, honestly that was not helpful at all.
I know that tranny coolers are installed in front of the rad, I've installed several aftermarket coolers over the years....
What I am trying to find out is HOW the factory cooler was installed, in other words actually attached to the vehicle.
After looking at my truck a little closer yesterday I am convinced I am missing mounting brackets, and that maybe even the rad support is different between the Dakota and the Durango.
I'll probably just end up using an aftermarket tranny cooler.
Old 09-21-2010, 12:46 AM
IndyDurango
I sure it involved at least one bolt.
Old 09-21-2010, 08:06 AM
Six_Shooter
You don't say...
Looks like aftermarket cooler it is....
Old 09-21-2010, 08:23 PM
MIKEon22s's Avatar
MIKEon22s
MIKEon22s is offline
They run verticle up and down a little off center of the radiator 2 lines come in from the bottom. Brackets just mount to radiator support.
Old 09-22-2010, 03:26 PM
Six_Shooter
Thank you.
You wouldn't happen to have any pictures of one of these installed would you?
Like I said in my OP, I have looked but haven't found any pictures.
Quick Reply: Tranny cooler pictures/install info.
