2nd Gen Durango 2004 - 2009
Durango Shaking a bit at idle..!
Old 05-17-2011, 04:49 PM
elacesar's Avatar
elacesar
elacesar is offline
Default Durango Shaking a bit at idle..!
Hello all and just thanking everyone for there help always.... My durango is giving me a little shaking at traffic lights and i actually did turn off once.. I have about 75,000 miles on it and i was thinking if its time to change the sparkplugs or should i raise the idle just a bit.. Thanks for all of your help..
Old 05-17-2011, 08:58 PM
n8ech's Avatar
n8ech
n8ech is offline
EL:
What engine does your D have? Could be in need of a set of plugs, or could be an EGR issue?
The owner's manual calls for plugs to be changed every 30K. if you do not idle a bunch, you can push that another 10-20K if you want. If they are original at 75K, time for new ones.
Idle speed is set by the computer, so as far as I know you cannot change it unless you have the appropriate computer to do so.
Its better to treat the cause than the symptom IMO.
Don
Old 05-18-2011, 02:08 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Don't mess with idle adjustments. Find the culprit. How is the battery? Plugs and wire age?
IndyD
Old 05-18-2011, 02:47 AM
Abqhemi's Avatar
Abqhemi
Abqhemi is offline
Make sure there are no codes, replace the plugs just to rule them out and put a can of sea foam in it.
Old 05-18-2011, 11:02 AM
elacesar's Avatar
elacesar
elacesar is offline
Thanks for all of the help.. I have never changed the wires nor the spark plugs so i guess its time.. Does anyone have any hints on removing those plugs cause they look like a pain... Thanks and i will post back in a few days..
Old 05-18-2011, 04:41 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
4.7 or Hemi? If 4.7, there are no wires. If Hemi, its not fun to change the plugs, but is doable. If Hemi, this may help, although its for the Rams, so it may not be exactly like the Durangos.
Old 05-18-2011, 05:20 PM
elacesar's Avatar
elacesar
elacesar is offline
Thanks and it is very similar.. I will work on it and get back to everyone this week.. Thanks again..
Old 05-19-2011, 11:03 PM
fr0gster's Avatar
fr0gster
fr0gster is offline
As Don asked in his post, please let us know which engine you have. This will help us with helping you.
Old 05-19-2011, 11:16 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Since he commented that my link was very similar to his setup, I am assuming he has the Hemi, but it'd be nice if he could verify this... (hint, hint).
Old 05-20-2011, 08:36 AM
elacesar's Avatar
elacesar
elacesar is offline
Thanks its a 5.7L Hemi engine..
Quick Reply: Durango Shaking a bit at idle..!
