Car pulls to the right under light acceleration automatic
Old Jul 13, 2010 | 05:58 PM
briann510's Avatar
briann510
Default Car pulls to the left under light acceleration automatic
Just noticed this happening and my daughter said it was doing it before I replaced struts as well.
Straight line acceleration light/medium throttle in between 3rd and 4th around 2200 rpms. It goes straight when shifting into each gear but after its shifts into 3rd a couple seconds afterwards before it goes into 4th the front of the car pulls noticeably to the left. I could understand it doing it right at shift point for torque steer feeling but not after its already shifted unless something is slipping some and grabbing again but hard to tell.
Its really noticeable if doing 65 mph on a long sweeping right hand curve the car wants to pull to the left if giving it a little bit of throttle through the turn.
Any ideas? It really doesnt bother me a lot but my daughter said it kinda scared her once as car was trying to pull the other way when going fast around a curve.
Old Jul 13, 2010 | 08:32 PM
sapporo's Avatar
sapporo
you had it aligned after doing struts?
check suspension bushings for play, ball joints for play and motor mounts. these things could cause your symptoms
Old Jul 13, 2010 | 09:44 PM
darthroush's Avatar
darthroush
Section Moderator
If I remember correctly, you had all of the suspension stuff changed already (bushings, tie rod ends, ball joints...) as well as the struts recently? It wasn't doing this before the strut change? If no, my opinion: get it put on a rack and have it looked at with all the proper tools.
Old Jul 13, 2010 | 10:12 PM
briann510's Avatar
briann510
Yes all suspension stuff was changed earlier this year and struts this last weekend. Daughter said car was doing it before strut change though so ruling that out. if it was suspension I would think it would do it at other times and not just after the 3rd to 4th gear throttle changes.
Ill be looking under again tomorrow and see what I can try to find.
Old Jul 13, 2010 | 10:30 PM
sapporo's Avatar
sapporo
check engine mounts too. and try cross rotating front tires. maybe it's a radial tire pull and 3-4 your going faster but then it's all a guess since we are not actually able to confirm the customer complaint
Old Jul 13, 2010 | 11:01 PM
briann510's Avatar
briann510
All engine mounts were changed in the last 6 months as well.
I just took the car out for some testing on long sweeping curves under moderate acceleration. It seems to me its just FWD torque pull in the upper gears. I hit it hard off a couple starts and it seemed to do it then as well.
Im gonna chalk it up to that for right now cause I cant find anything loose under there or needing replacing as pretty much all suspension parts have been replaced this last year. Altho every once in a while ill get a clunk when hitting man hole cover depressions in the road.
My sons supercharged Cobalt had torque steer bad and thats what it feels like just on a much smaller scale.
Old Jul 14, 2010 | 12:28 AM
darthroush's Avatar
darthroush
Section Moderator
Those SS Cobalts do have that badly. Good to hear, because if it wasn't anything else, I was thinking bent control arm.
Old Jul 14, 2010 | 03:10 AM
briann510's Avatar
briann510
I thought that also but both arms are new....Im not sure ball joints were replaced so im gonna check those tomorrow.
Old Jul 14, 2010 | 12:15 PM
Moparkyle's Avatar
Moparkyle
If you are bent on thinking it's torque steer, check you CV's and check the rubber on the axle too.
Old Jul 14, 2010 | 04:21 PM
briann510's Avatar
briann510
Well im not exactly bent on that assumption...LOL
Its only happens in 3rd gear before going into OD 4th so Im thinking its not that now. I cannot get it to do it in any other gear or any other rpm cept right around 2200-2500 rpms.
No biggie as its really not a big deal just one of those weird things you just notice..
