Batt thermal wrap
Old 08-26-2010, 02:25 PM
seaneon00's Avatar
seaneon00
seaneon00 is offline
Default Batt thermal wrap
Hey...how important is the thermal wrap on the battery. I replaced my batt with an optima yellow top (I know it's prob overkill, but it was free) and the thermal wrap doesnt really cover the who thing. Will my battery explode? Thanks.
Old 08-26-2010, 04:18 PM
leprechaun1874's Avatar
leprechaun1874
leprechaun1874 is offline
no, it will not explode . I dont even think that mine has it still.
Old 08-26-2010, 06:17 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
Did it have a sensor attached to it?
Old 08-26-2010, 06:44 PM
seaneon00's Avatar
seaneon00
no, there was no sensor... I got it to fit well anyway by taking the batt out and putting it on first...I was just trying to jam it on after. I've never replaced a battery before and was all worried. I'm new to cars in general and I'm trying all sorts of stuff and get all anxious about doing it perfect. but anyway...it's on there so thanks!
Old 08-26-2010, 07:12 PM
darthroush's Avatar
darthroush
Section Moderator
If the wrap doesn't have the sensor, then don't worry about it. It's not essential. Since you got it on though, there's some FYI for you, lol.
Old 08-26-2010, 09:15 PM
showsxt's Avatar
showsxt
showsxt is offline
I just got a new diamond plated battery cover for my red optima and had to keep the thermal around mine seeing it has a sensor. Most of the older yrs dont have them probably just the 03-05 neons .
Old 08-26-2010, 09:25 PM
darthroush's Avatar
darthroush
Section Moderator
Not even all of the 03-05 Neon's have them. From what I've seen, there are more people that don't have that dumb sensor than those that do! Craziness I tell ya!
Old 08-27-2010, 04:40 AM
sapporo's Avatar
sapporo
sapporo is offline
I got on that is heated. must be a cold weather option.
Old 08-27-2010, 05:25 AM
darthroush's Avatar
darthroush
Section Moderator
I have it, and I'm located pretty far from cold weather. It's a sensor the computer uses to determine the battery temperature and regulate the charge rate from the alternator. If it isn't hooked up, your battery won't charge properly. Some have gotten rid of the wrap, and somehow rigged the sensor up to be close to the battery.
Old 08-27-2010, 05:42 AM
sapporo's Avatar
sapporo
sapporo is offline
no, mine actually has a heating element. there's a 110v plug tee'd into another plug into the block. it's listed as a cold weather package. the car came from far northern MN.
Quick Reply: Batt thermal wrap
