neon accident HELP
Old 10-02-2011, 09:50 PM
livin4wife's Avatar
livin4wife
livin4wife is offline
Default neon accident HELP
My daughter was in an accident in her 2003 dodge neon. After the accident the officer told her to shut the car off. The car was towed and now it will not start. I've heard of newer vehicles having a shut off switch and I've been told that only Ford has this feature. Is there any one out here that KNOWS if this car has one and if so where it may be found, so I can reset it and get the car back on the road.
Old 10-03-2011, 05:49 AM
vpnavy's Avatar
vpnavy
vpnavy is offline
Welcome Aboard livin4wife! Stay tuned - a Technician (or member) will jump in shortly to provide a possible solution. In the meantime, don't forget to browse Sub-Forums: Neon for stuff related to your ride.
Old 10-03-2011, 07:59 AM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Dodge Forum Moderator
Welcome to the site. I moved this thread to the second generation Neon section,
FF
Old 10-03-2011, 04:12 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
The Neon does not have that system AFAIK. In the Ford's, the inertia switch as it's called will automatically shut the fuel pump(s) off in an accident; it doesn't wait for you to turn your car off. Does the car still turn over?
Old 10-04-2011, 02:01 PM
livin4wife's Avatar
livin4wife
Angry
I have radio, wipers and dashboard lights, turn the key over and nothing. I can't even hear the fuel pump turning on. I'm at wits end. grrrr
Old 10-04-2011, 03:53 PM
leprechaun1874's Avatar
leprechaun1874
leprechaun1874 is offline
Are you using the original factory key or the valet key? After my wife wrecked her neon the valet key would not work any more
Old 10-04-2011, 06:38 PM
darthroush's Avatar
darthroush
Section Moderator
Perhaps the ASD (Auto Shutdown) relay tripped? Have you checked that? It gives or takes power to or from most everything the car needs to run.
Old 10-07-2011, 11:21 PM
livin4wife's Avatar
livin4wife
Is there a way to check the relay or should I just buy another relay.
Old 10-07-2011, 11:22 PM
livin4wife's Avatar
livin4wife
Original key no valet
Old 10-08-2011, 04:52 AM
darthroush's Avatar
darthroush
Section Moderator
You can switch the ADS and fuel pump relay (assuming the fuel pump relay is good).
Quick Reply: neon accident HELP
