Burning Oil
09-29-2012, 11:44 AM
on
Burning Oil
Security reasons
Reason: security
09-29-2012, 03:40 PM
on
What exactly did you rebuild? And can you actually see smoke coming out of the exhaust?
09-29-2012, 03:59 PM
on
security reasons
Reason: security reasons
09-29-2012, 04:55 PM
on
Did you hone the block when you put everything back together?
09-29-2012, 05:51 PM
on
security reasons
09-30-2012, 01:11 PM
on
Ahhhh because if it wasn't honed correctly the rings may have never gotten a chance to seat correctly.
09-30-2012, 10:00 PM
on
Quote:
Originally Posted by
Moparkyle
I'm not a mechanic, but how often do you have to hone the block to make those rings seat correctly? I thought those rings were sized correctly?
What exactly does honing the block mean?
09-30-2012, 11:09 PM
on
It needs to be done anytime you replace rings and it is usually a good idea to do it whenever you remove the piston from the cylinder.
It removes the glaze from the cylinder wall.
If you want a more in depth explanation there are plenty of websites out there that can describe it further.
11-18-2012, 05:00 PM
on
security reasons
11-18-2012, 05:20 PM
on
Are you sure it's not leaking somewhere? There was a post on here that had the same issue, and they couldn't find what it was. It was the oil pressure sending unit, which would explain loss of oil, and no smoke in the exhaust.
