2003 dodge neon sxt
Old Jan 12, 2014 | 09:40 PM
settle91's Avatar
settle91
Default 2003 dodge neon sxt
I have a 2003 neon that I bought for my wife. The previous owner hit a ditch, anyways now that it belongs us I find myself fixing a bunch of things which is no big deal things like this will happen, but there is one thing I can't figure out? Which is when the car gets above 2000 rpms it vibrate very bad and gets loud also when its about to shift, but seems like it shifts fine and I have checked the pulleys I don't think its any of those this problem is just really annoying and doesn't really seem to effect the performance idk what else it could be?
Old Jan 12, 2014 | 11:28 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Do you have the 2.4 engine or the 2.0 ? Because if you have a 2.4, the problem could be a balance shaft. I will move your post to the 2nd gen neon section.
Old Jan 13, 2014 | 12:46 AM
settle91's Avatar
settle91
Yeah its a 2.0 and thank
Old Jan 13, 2014 | 02:02 AM
darthroush's Avatar
darthroush
Section Moderator
Could be broken torque struts, engine mount and/or transmission mount.
Old Jan 14, 2014 | 02:06 AM
settle91's Avatar
settle91
Any other tips?
Old Jan 14, 2014 | 08:12 AM
richards83's Avatar
richards83
I would go with what darth said. Torque struts, engine mount, trans mount.
Old Jan 14, 2014 | 12:03 PM
darthroush's Avatar
darthroush
Section Moderator
Originally Posted by settle91
Any other tips?
Did you check those?
Old Jan 14, 2014 | 08:37 PM
settle91's Avatar
settle91
There is side tears on the left of the top one and the right of the bottom which makes me think the middle one is bad? Its vibrating on the side with the motor mounts not the trans mount
Old Jan 14, 2014 | 11:14 PM
darthroush's Avatar
darthroush
Section Moderator
Yeah, usually if the torque struts go bad the middle motor mount goes bad rather quickly, especially if one got into an accident that would jolt the car good. Based on that and the vibrations right around 2,000 RPM, I'd personally replace the mounts.
Old Jan 15, 2014 | 04:08 AM
settle91's Avatar
settle91
Ok thanks a lot for all the help from all of you I really appreciate.
