Old May 6, 2013 | 09:47 PM
  #11011
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by snowboundrmk
Good I was thinking (and hoping)it was the top end.
I'm gona put some new Odessa's on when I do my carb swap.
That should last until I can afford to build a 408(after college...and high school...)
You should likely get a second opinion as I am not very well learned in that area, but that's what it points to for me.
Old May 6, 2013 | 10:26 PM
  #11012
crazzywolfie's Avatar
crazzywolfie
i got my ramcharger back together and cleaned it out and gave it a bath to make it pretty for when i go to pick up my sister from the airport.
Old May 6, 2013 | 10:27 PM
  #11013
dodge dude94
Did you ever that that floor pan thing figured out?
Old May 6, 2013 | 10:50 PM
  #11014
crazzywolfie
no. been to busy to call them and see if they figured it out. i have a feeling they will never really straighten it out. i may just make my own passenger floor pan when i have time or make the current fix a bit more permanent. cut up the old drivers floor pan and used some self tapping screws to screw it down to the passenger side supports.
Old May 6, 2013 | 10:52 PM
  #11015
dodge dude94
That sucks. I would think modifying the other drivers side might work.
Old May 6, 2013 | 10:58 PM
  #11016
QuadCabLuv's Avatar
QuadCabLuv
Yesterday i put on a new starter and today I did a compression check. Here are my results test was done dry and with four cycles each cylinder:
1: 90
2: 128
3: 90
4: 123
5: 148 down
6: 125
7: 120 down
8: 120
Cylinder 5 and 7 leaked down at a decent speed after the last cycle
Truck has 185,000 miles and blue smoke comes out on startup. The oil is also pretty milky and has been in for only 30 miles.
What do you think is causing these numbers?
I'm betting on blown headgaskets.
Old May 7, 2013 | 07:56 AM
  #11017
redneck_ram's Avatar
redneck_ram
got my first custom tune from hemifever last night. gonna go load it up in a bit!
Old May 7, 2013 | 09:04 AM
  #11018
bkupkee's Avatar
bkupkee
Walked the yard yesterday, and found a NON-cracked windshield water tank...$9.00 w/motor!
Old May 7, 2013 | 09:42 AM
  #11019
1: 90
2: 128
3: 90
4: 123
5: 148 down
6: 125
7: 120 down
8: 120
Do a wet test as well, and see what the numbers do.
Old May 7, 2013 | 11:13 AM
  #11020
redneck_ram
custom tune is loaded! drove the truck 15ish miles, and wow! my energy suspension motor mount inserts came in yesterday. need to buy new motor mounts now.
drivers header was thought to be hitting the frame, come to find out its the passenger header hitting the trans pan lip.... WTF! pics later to show dent.
