Old Jul 5, 2013 | 01:11 PM
  #11721
ChillyPhil's Avatar
ChillyPhil
Checked the power steering fluid and it's full. Where's that belt you said to check at?
Old Jul 5, 2013 | 01:13 PM
  #11722
aofarrell2's Avatar
aofarrell2
The fan belt that drives the water pump. Push the belt in with your finger: it shouldn't deflect more than half a inch. If it does, either the belt is stretched, or the tensioner has failed to do its job. Also inspect it for cracks, and missing ribs. Either of the latter can cause a serp belt to lost traction, even if it is tight enough.
Old Jul 5, 2013 | 01:14 PM
  #11723
crazzywolfie's Avatar
crazzywolfie
How much electronics do you have in that truck? Jeez....I think a 100amp alt on my 76 would be interesting.....
i think i did the math once and if i turned most of the stuff on all at once things would be pulling about 90amps. now i think i read that i will fuse the amp for 40 so if it does pull that much power i may need the 136 amp alternator.
it is a bit hard to find brackets for the 100 amp alternators but they are out there.
Old Jul 5, 2013 | 01:16 PM
  #11724
aofarrell2's Avatar
aofarrell2
Get a Delco one wire, 90amps at 800RPM. It has a very good regulator built into it. One wire goes to the battery +, the other goes to battery -. They are called one wires because they are sooo easy to install, I did it on my JD diesel, cuz ol Johnny wanted $250 for a reman and I got this one for $65 new.
Old Jul 5, 2013 | 01:28 PM
  #11725
crazzywolfie
why the heck would i buy a delco alternator when i when i got a heavy duty 100 amp alternator with all the brackets.
Old Jul 5, 2013 | 01:29 PM
  #11726
aofarrell2's Avatar
aofarrell2
I was just making a suggestion...
Old Jul 5, 2013 | 02:56 PM
  #11727
Gary-L's Avatar
Gary-L
Veteran: Navy
Because all the cool kids are doing it, that's why.
Old Jul 5, 2013 | 03:20 PM
  #11728
aofarrell2's Avatar
aofarrell2
^lol... Actually at 12000 RPM the delco one wire puts out 160amps I think.
Old Jul 5, 2013 | 03:33 PM
  #11729
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^But who actually runs their engines at 12000rpm?
Started soaking the shock bolts on the 76 in pb blaster today. Realized that a ton of the crap that's attached to the frame is just dirt that could be blasted off with a pressure washer...
Old Jul 5, 2013 | 06:54 PM
  #11730
Rescue35's Avatar
Rescue35
^Alternator speed will be higher thzn engine speed (smaller diameter pully on the alternator).
I bought 11 bags of mulch on sale. Parked the truck and started tearing down the engine to do the plenum, timing set, waterpump. All with the mulch still in the bed.
