He just said that it wears out quicker than normal. He recommended Mopar witch merc on here also recommended.
I'm just getting a new replacement stock and putting a tensioner on it. It should last the rest of the life time of the truck I'm hoping.
About fawkin time Merc!!
Are you going to flap all that surface rust off or use a blaster? Don't forget your tetanus shot! lol Dude, start a single thread to document your rebuild, people will want to know.... While there have been some threads on it here, they severely lack the tech/steps of what is involved.
So how in the world did this unfortunate accident happen? How does a measely 1500 help a heavy **** Hummer? lol Looks like some itty bitty car wanted to get b/t them?
Used 1999 era Dana 60 front and Dana 70 rear 4.10 gears and rear LSD, got a great deal on them to boot, Thanks Colton. Next is new wheels just need to pick a size under 18" Dia and colour, then gear ratio. Not too many parts left to get before I can start the new lift and diff install. The new trac-bar is on its way up from SC should be here next week sometime, Thanks Jeff351 for the great deal and your time.
Rear still has the tag on it.
Edit;
Edit;
While getting ready to order more things for my truck. Got a call from some of my friends that they had been in an accident on the highway. So I drove 50 miles to the scene today to rescue some friends,that what I did to my ram today. Thank goodness nobody was injured. Friends are still quite freaked out about what happen.
For cleaning them I am going to try high psi liquid media blasting, I have heard good things on this. I think I will do a Diy thread once I am done this work, I don't get on here enough in the summer to keep the thread updated on a reg basis.
Today I go pick up new drums, shoes, pads for the diffs. I will also be ordering new anti-wrap leaf spring pads 2.5" x 6". The pads must be moved out wards 1/2" on each side on the 60, 1500 pin to pin width is 44.5" the 2500 pin to pin is 43.5". I am also working on figuring out the rear DS issue.
^^^ Thanks but I am just going to stick with the 60 as I have most of the parts needed for it EI locker, save me some $$$ on not needing a 70 locker. If I need to I can find a 70 later on for it. I have that info from WN as well good info to read over.
Feel like doing me a favor? would you measure your rear DS weld to weld for me?
How's the new house???
Edit: My Dodge dealer has spring perches in stock so they are what I will be using, dirt cheap $12 for the pair. Mopar Performance P4120074 - Mopar Performance Spring Perch Brackets. So I will see if these old eye's can see well enough to still weld a good bead soon.
Just a link to them http://moparperformance.carshopinc.c...36973/P4120074
i picked up a 390cfm holley carb for my 81 for $50 today. it looks to be in pretty good shape but i will find out once. i take the float bowls off. i hope i can make sure things are clean and then toss it on. on the way to pick the carb up my dad and me spotted 2 rv batteries thrown to the curb so we picked them up and took them to buy me a rebuilt interstate battery. cost $56.50 but after we scrapped the 1 battery it was only about $45. now i just have to install it.
