Old Sep 1, 2009 | 11:15 PM
  #1251
my 4.7's Avatar
my 4.7
Stay with regular brakes its better for your rotors, they are softer and cause less heat which in return your rotors wont warp as easy,,,,
Old Sep 2, 2009 | 03:14 AM
  #1252
Sheriff420's Avatar
Sheriff420
ceramic brakes suck. they don't stop as well and warp the rotors easily.
6000k hid lights are the way to go.
Old Sep 2, 2009 | 10:39 PM
  #1253
Oren09's Avatar
Oren09
Put my grill back on after I gave the epoxy 24 hours to cure.
Changed my transmission filter and pan gasket. The magnet in the pan was doubled in size with deposits and the pan was full of sediment and pieces of something- cork, rubber, dirt- I'm not sure.
Checked coolant freeze protection. The coolant I drew into the tester was clear, but all the ***** floated to the top... The coolant in the tank looks orange, but it has stuff floating in it. I took off the radiator cap and the thermostat is rusty and the radiator appears to be rusted inside.
I'm a little worried about the coolant because winter is coming up and I've heard it gets below zero here sometimes. My truck has been in Texas all it's life and never below 10 degrees.
I was going to exchange the fluid in my transfer case, but I'm not sure how to remove the plugs. They appear to be large hex shaped holes- maybe a large allen wrench will work on these..? Any idea what size they are?
Also, a seal in my transfer case is leaking, about in the middle of the skidplate. How hard is this to replace?
Old Sep 2, 2009 | 10:50 PM
  #1254
Ram15002ndGen's Avatar
Ram15002ndGen
That's either gasket material or filter material. It was due for a drain & fill. Your radiator sounds like a rust bucket. Get a new cap, and flush that baby. Anything other than green is bad for your truck. Get some Prestone. The PO probably put the WalMart crap in there. I tried it and it turns to rust real fast. I stick with Prestone now.
Old Sep 2, 2009 | 11:39 PM
  #1255
Mechanik's Avatar
Mechanik
Finally got around to restoring my headlights. They were pretty bad and I got a kit from Advance Auto called Crystal View and I'm really happy with the way they turned out.
Before:
After:
Much better.
Old Sep 2, 2009 | 11:48 PM
  #1256
Miami_Son's Avatar
Miami_Son
Holy crap! What did you paint your fender with, Krylon?
I had to buy a new battery for my baby today.
Old Sep 2, 2009 | 11:54 PM
  #1257
Twisted Metal's Avatar
Twisted Metal
HOLY ORANGE PEEL BATMAN!
Old Sep 3, 2009 | 12:43 AM
  #1258
Oren09's Avatar
Oren09
LOL @ Twisted.
Ram1500, thanks for the info.
It probably was some generic crap.
I'll need to add that to my to fix/replace list. Damn, just when it was almost down to two pages..
Should I just drain out the old coolant and pour in new, or is there something else I need to do..?
Old Sep 3, 2009 | 12:54 AM
  #1259
smoke stacks's Avatar
smoke stacks
i need to do that too. every once in a while some coolant will leak out in front of my left front tire...it drips off the left of the front fender. when i fill the reserve back up i notice a dirty or rusty brown color...i hope i dont need a new radiator. you better jump on it oren09 before yours ends up like mine. btw im def going to try that headlight fixer.
Old Sep 3, 2009 | 12:55 AM
  #1260
Ram15002ndGen
LOL @ Twisted.
I would suggest getting yourself an over the counter radiator flush. It only costs a few bucks, and it helps get rid of any contaminants that are in there. Follow the instructions, then fill with fresh coolant (50/50) and enjoy a clean cooling system. Use good coolant. Like I said I used the WalMart crap when there was like a 5 dollar difference. Now WalMart crap is $1 less than Prestone, "No Thanks".
BTW I learned a long time ago that coolant doesn't last very well past one year. To keep my cooling system clean, I drain and refill with new coolant at the start of Summer each year.
