#1261
Again, thanks for the info. I'm going with 60/40 because the winters here sometimes see -20 and I really don't want a cracked block. My mom had a 95 Ram that had lived it's whole life in Texas and she didn't change the coolant when she moved up here a couple of years ago. It got very cold and cracked the block.
@Mechanik or anyone else who's done that: Did you just use sandpaper or a brush/buffer wheel for a drill/dremel?
#1262
#1263
on
oren, i believe there are a couple plugs on the side of the block that you have to take out to flush the cooling system properly. if you are going to mix the coolant yourself then don't forget to use distilled water and not tap water. while you are flushing the system you should also check your thermostat.
#1264
That's either gasket material or filter material. It was due for a drain & fill. Your radiator sounds like a rust bucket. Get a new cap, and flush that baby. Anything other than green is bad for your truck. Get some Prestone. The PO probably put the WalMart crap in there. I tried it and it turns to rust real fast. I stick with Prestone now.
#1266
