Old 04-16-2014, 12:35 PM
Jigabop's Avatar
Jigabop
Jigabop is offline
the alarm would still go off if you opened the door with it locked either way, but the horn wouldn't been letting you know that you just locked the doors... I used to have to listen for the click from the door locks or watch for the red flashing light... now I can hear it toot when it locks much better!
  #13732
Old 04-16-2014, 12:50 PM
redneck_ram's Avatar
redneck_ram
redneck_ram is offline
There is a relay in the PDC for the O2 sensor heaters. (I think) Swap that relay with another one, and see if the codes stay gone.
Heyyou you are the man! I went out and checked mine and for whatever reason the o2 heater relay wasnt there but there isnt a socket for it.. however there is also a fuse for the o2 sensors mine was blown. Im hopong problem solved!
Size:  122.0 KBName:  20140416_124122_zpsdqauvj4k.jpg
So ill elaborate on the heater relay missing..
Its impossible to plug a relay into the socket as it just falls in. However I dont have a security system but there is a relay for it. So mYbe its for the o2 sensor heaters...
  #13733
Old 04-16-2014, 01:58 PM
stewie01's Avatar
stewie01
stewie01 is offline
Topped the tank off, $43 @ $3.39 a gallon. Driving town to Mt. Airy on Saturday morning to meet up with Mr. Eaton
  #13734
Old 04-16-2014, 02:48 PM
redneck_ram
you should drive up this way some time!
  #13735
Old 04-16-2014, 03:29 PM
stewie01's Avatar
stewie01
stewie01 is offline
That would be a fun drive but you aren't exactly close...
  #13736
Old 04-16-2014, 05:27 PM
Johnn123's Avatar
Johnn123
Johnn123 is offline
Now I found that too, there is no plug for the relay. It just falls in. I though someone yanked em or something for some stupid reason, nope just nothin there it seems. Im gonna check the security system relay now that ya say that though, never noticed that before.
  #13737
Old 04-18-2014, 01:03 AM
topkin's Avatar
topkin
topkin is offline
Instaled my Flowmaster "Direct Fit"(ha yea... right) Cat that came two weeks ago and replaced my passenger side wiper blade. Original cat was partialy cloged due to a fuel problem a while back. Sounds pretty good, noticable differance in getting up to speed and power up hills. Also took it to a mechanic to have the plenum checked out and everything is looking good; not burning oil, idles and runs great, no smoke out the tailpipe, no pooling inside the manifold. OEM plate though .
  #13738
Old 04-20-2014, 12:22 AM
kissmymagnum's Avatar
kissmymagnum
kissmymagnum is offline
A friend gave me a set of headlights from a '00 Sport that he replaced. The only reason is that they were very hazy and yellowed. I got 2000 grit sandpaper and wetsanded the heck out of them, then sprayed 5 coats of clear on them. Nice and clear now. I finally got to install them today and made a custom harness with relays for the brights so that all 4 bulbs are lit with the brights. Even better, I didnt touch the factory wiring so I could change it back if I ever had any reason to. It looks so much better already, especially with the lenses being clear. Almost makes the truck look newer. Time for a paint job next since the clear is starting to go.
  #13739
Old 04-20-2014, 12:39 AM
tincan57's Avatar
tincan57
tincan57 is offline
Smile Good timing
A good friend of mine recommended the same process to clean up an old head light. Thanks for posting. I have one in need on a 2500.
Used to live near Lincolnton once.
  #13740
Old 04-20-2014, 02:40 PM
kissmymagnum
The paint holds up so much better than just polishing them. I had 2000 grit sandpaper and the hose nearby to keep them rinsed and to keep them wet while I worked. I have done them in the truck and out, out is considerably easier but a lot more work if you are not changing them like I just did. Just make sure that you mask everything off well and use quality clear paint. My last headlights went six years after and still look decent. Never did get them as clean as I got these though. Takes a lot of patience and elbow work. They will look very hazy as they dry but the clear will take care of that in even coats.
Quick Reply: What Did You Do To Your 2ND GEN RAM Today?
