Old 03-14-2019, 10:32 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,189 Likes on 2,942 Posts
Originally Posted by 1997DodgeRam
Changed plugs and ignition coil. Need to order a distributor cap and get to the bottom of a it don’t start when raining issue.
Get plug wires too then.
  #16202
Old 03-17-2019, 10:31 AM
1997DodgeRam's Avatar
1997DodgeRam
1997DodgeRam is offline
I just ordered wires and am really glad you said that. It made me go back and double check and it’s the wires that are 13 years and 90k old and the distributor that is only 5 and 35kish. Had it backwards in my head after I mentally latched onto distributor, will do all when I get to it.
  #16203
Old 03-17-2019, 04:59 PM
Spillage's Avatar
Spillage
Spillage is online now
Today I put openings in my hood for some louver vents (AKA 5.9 ZJ).
They're at a bit more of an angle than I would have liked, but that was governed by the slots in the hood frame.
I cut a plastic template for the mount holes and the cutout... flipped it for left/right side.
Drilled the first two holes from the underside through the slots, then line the template up on those holes an do the rest from the top.
When done and deburred, I shot the edges with some primer to keep rust at bay until the cabs repainted.
  #16204
Old 03-17-2019, 07:09 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
I like that!
  #16205
Old 03-22-2019, 06:49 PM
racefan41's Avatar
racefan41
racefan41 is offline
Yesterday I worked on getting the old sound mat off the floorboard using the dry ice and alcohol then chip it off trick. Didn't have much luck with that method. That shi!t is on good. I got the idea to use my fine tool (that's what we call it at work)http://makita.thetoolstoredirect.co....ter-body-only/
Put a wood cutting blade on it and took it right up. Gotta get more 60 grit for my sander tomorrow to get the rest of it up and get rid of the surface rust under it. Luckily its only the two front seat sections that need done. Then we're gonna treat and lay sound mat all around.
  #16206
Old 04-02-2019, 06:48 PM
Spillage's Avatar
Spillage
Got the replacement bed painted...
Working on the cab next.
  #16207
Old 04-02-2019, 08:48 PM
HeyYou is offline
Wow. That looks rather nice.
  #16208
Old 04-02-2019, 09:44 PM
Spillage's Avatar
Spillage
It’s red... a good start.
  #16209
Old 04-15-2019, 07:01 PM
Spillage's Avatar
Spillage
I have more red for you...
I got the bed back on this evening... I’ll start on the rest of the bits over the weekend.
  #16210
Old 04-15-2019, 07:06 PM
HeyYou is offline
Wow, that's really Red. Looks rather nice.
Quick Reply: What Did You Do To Your 2ND GEN RAM Today?
