Old 05-06-2010, 01:25 AM
2k10HemiRam's Avatar
2k10HemiRam
2k10HemiRam is offline
First I put on my DF decals I just got
Then when I got bored I decided, even though I'm going to get rid of it when my new bumper gets in, to paint my brush all black again. first I started with just rustoleum rust reformer but 1 can wasn't enough to do the whole guard. So I said screw it, grabbed the two cans I have of their under coat and sprayed the guard down. The undercoating is a rubberized compound and boy, when they say to hold the can 12-16 inches away from what you're spraying, they weren't kidding. That stuff shots out crazy. Still can't hook my camera up to the puter to d/l the pic's so my cell will have to do.
After masking, before painting
first coat of just rust reformer
Final coats of the undercoating
I'll post pictures of it tomorrow, got too dark to really get a good look at it by the time I was finished.
  #3612
Old 05-06-2010, 06:45 AM
mnewbolds's Avatar
mnewbolds
mnewbolds is offline
Originally Posted by bigtman07
Trying to replace my passenger side U-joint. I can't get the dang nut off. Already broke 2 1/2inch ratchets and now workin on a breaker bar. I know why not the bar first.... Well cause I don't really have the extra money around to go buy tools. Been soaking it down with pb blaster all afternoon. If it doesn't come off tomorrow I'm gonna try to torch the nut. If not I'm lost. You guys got any other Ideas?? I'm doin a search but I'm not liking what I'm reading. Oh also got the long a$$ pipe to help.
If you can get ahold of an impact gun try that. If it won't back off, try hitting it a couple of times forward (not hard) and switching to reverse and hitting it again. Is this the axle nut or the 12pt bolts on the back of the spindle?
  #3613
Old 05-06-2010, 10:14 AM
bigtman07's Avatar
bigtman07
bigtman07 is offline
It's the actual axle nut. Not the inner bolts. Haven't gotten to them yet. Should I get them out first?? Plz say its don't matter Please!!!! lol I'm being turned into a tow service and my truck was actually making me money. lol
Edit: To make sure i'm not a complete retard and breaking ratchets for no reason.... Turning the nut to the front of the truck tightens and turning to the back of the truck loosens right???
  #3614
Old 05-06-2010, 10:39 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
I've heard that some Rams have reverse threads on the passenger side hub nut but mine didn't. Turning toward the back of the truck loosens it. You can look at the threads and see if it is reverse threads. If the threads on the left side of the stub shaft are closer to you than the right side then it is right hand threads, they will be slanted to the right.
  #3615
Old 05-06-2010, 01:30 PM
bigtman07's Avatar
bigtman07
Yea Haynes says that the driver side is reversed. Good news though. I got the nut off with the help of some heat. Now next problem is the hub assembly won't come off. I took off the three bolts holding it in. Been beatin on it for an hour with no luck. Any suggestions? I'm gonna start a new thread so I don't hijack the what did you do today thread.
  #3616
Old 05-06-2010, 03:25 PM
004x41500's Avatar
004x41500
004x41500 is offline
contemplating converting to e-fans, but i dont knwo what im to do about my washer flid jug, and the coolant jug...
any ideas?
  #3617
Old 05-06-2010, 03:35 PM
Sheriff420's Avatar
Sheriff420
004x41500, I'm looking to do the same thing. Advance has a coolant jug with a wire basket type deal that would work for the coolant but I don't know about the washer fluid...yet.
I just got back from the junk yard where I was looking for a 90-95 ford taurus/lincoln/sable with the 3.8L motor to steal the fan off of, but the cars that had the right motor in them didn't have the fan.
Look at these sites and you'll see that you can do an e-fan pretty cheap.
https://dodgeforum.com/forum/3rd-gen...c-fan-diy.html
http://www.jeepforum.com/forum/f13/f...l-pics-233676/
http://www.fordmuscle.com/archives/2...cfan/index.php
  #3618
Old 05-06-2010, 03:50 PM
BlueBeast2's Avatar
BlueBeast2
BlueBeast2 is offline
how much you wanna spend?
  #3619
Old 05-06-2010, 09:10 PM
jake7's Avatar
jake7
jake7 is offline
I changed the u-joints (front and rear) and replaced the o2 sensor. Runs a lot better now....still has a few problems; going over 90 is rough and throwing p0442 code...Will be searching for that solution tomorrow.
Anyone have an in-dash dvd player? Like it? Brand?
  #3620
Old 05-06-2010, 11:47 PM
DukeSupes's Avatar
DukeSupes
DukeSupes is offline
JB welded the bracket that holds the windows rail to the door as it broke loose. No more clanking when I shut the door or driving down the road!
Quick Reply: What Did You Do To Your 2ND GEN RAM Today?
