Old Dec 15, 2010 | 03:32 PM
  #5111
tneville's Avatar
tneville
^Fix that passenger side headlight housing...looks like crapola.
I thought you liked you plasti-dipped wheels.
The Plasti-dip was great for a quick fix kind of a thing for a person on a budget. It was just temporary till i found something better. As for the lights, I used that stuff that takes the fog off but it just came back. My plan now is to sand them down and use some vht
Old Dec 15, 2010 | 09:19 PM
  #5112
joshmopar's Avatar
joshmopar
Fixed joshbetterhalf (user name, real name candace) Anyways fixed her positive battery terminal. It was loose as heck.
Also did some work on the cummins. I put a cb radio in. Ill get some pics probably this weekend. But i still have to put the dang antenna on and get the antenna tuned to the radio. Also having a friend of mine build a headach rack and rear bumper. Yea its gonna be one tough truck. Oh and yall didnt know I already have a nice heavy duty front bumper
Josh
Old Dec 15, 2010 | 09:43 PM
  #5113
Ram4x45.9's Avatar
Ram4x45.9
Default 1997 dodge ram
I bought some hubs off ebay for my ram truck.
it has a dana 60 front axle.i notice the hubs i took of my
truck had landing pads for the spindle washer and for the 4 hub bolts
but the ones i got off ebay dont.Whats the difference between the two?
Appreciate any help.
Old Dec 15, 2010 | 10:20 PM
  #5114
joshsbetterhalf's Avatar
joshsbetterhalf
Apparently Dodge didn't make the battery terminal connectors to fit Optima batteries... the post on my battery just was too slim to have the connector tighten down to size. No idea how it was doing it before, but yes, my loving fiancee fixed it for me.
Hoping this will solve the hesitation problems.
Old Dec 16, 2010 | 08:10 AM
  #5115
Sheriff420's Avatar
Sheriff420
Got a picture of yours vs. the new one? The 1/2 ton Rams have a Dana 44 in the front and they only have three hub bolts that hold them on. I thought the D60 had three as well, does it have four bolts that hold the hub on?
As for what I did to my Ram>
Put my Champion truck plugs back in and this:
Old Dec 16, 2010 | 09:50 AM
  #5116
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Got it aligned yesterday, steering is straight now. Yay!
Also had the shop air the tires up to 40psi....the manager said, "Uhh, 40? Thats a bit high..."
I told my mom (who took it to the shop for me) to make them do it anyway if they want to balk and complain..I know what the hell I'm doing. Thats sorta what she told em. Got another inch or two out of the truck too.
Consequently, the manager explained the alignment stuffs to me....apparently the camber is maxed out....then I find out via my FSM that the camber is non-adjustable.
Oops.
Old Dec 16, 2010 | 10:28 AM
  #5117
Sheriff420's Avatar
Sheriff420
I wonder what that shop would say about me running 50psi in mine.
Old Dec 17, 2010 | 03:38 PM
  #5118
Sheriff420's Avatar
Sheriff420
I cleared some check engine codes today and got rid of a misfire.
I disconnected the vacuum line from the brake booster the other day so I could access the header bolts and I forgot to plug it back in.
I thought the engine was running a little rough when I first started it and figured that it may not like the new plugs. I knew what the problem was when I took the brake off with my foot on the brake pedal and the truck moved.
Did you know that running the truck with the brake booster disconnected will give you a P0201, P0206, P0300 and a P0301 code? I do now.
Old Dec 17, 2010 | 05:33 PM
  #5119
dodgeram07's Avatar
dodgeram07
nice work Sheriff
Old Dec 18, 2010 | 11:20 AM
  #5120
Sheriff420's Avatar
Sheriff420
Thanks dodgeram07.
I gassed up last night at a gas station that has produced plenty o' spark knock in the past and heard something pleasant this morning.
Cruising along at 70 mph on an incline with the gas pedal pressed just shy of kicking out of overdrive I didn't hear any knocking.
Later on down the road I floored it up to about 70 mph and once again, no knock.
I don't know if it was sealing that friggin crack in the header or the Champion truck plugs that made it happy since I did them at the same time but the engine is nice and quiet now so I'm happy.
