Old 10-22-2011, 05:58 PM
EndIsNear's Avatar
EndIsNear
EndIsNear is offline
Rolled over 140000. me and my pickup are getting old...
  #5872
Old 10-22-2011, 06:42 PM
Jimythefan's Avatar
Jimythefan
Jimythefan is offline
Originally Posted by BackwoodsRam
i ordered on of those glowshift 3 gauge A-pillars from ebay, and dream shoped for gears and lockers as well
I'd be interested in how you install that over the stock pillar cover. What holes you need to drill or any issues with it. I'm getting ready to order mine too.
On topic. I installed new yellow foglight bulbs, had my flat sparetire replaced, and had the cooling system flushed at the dealer.
  #5873
Old 10-22-2011, 07:09 PM
BackwoodsRam's Avatar
BackwoodsRam
BackwoodsRam is offline
Man your truck is young compared to mine, ill probably break 190k by the end of the year. And jimmy ill make sure to let you know how i attach it if you pm me a reminder
  #5874
Old 10-23-2011, 03:55 AM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
New water pump, thermostat, upper, lower, and bypass hoses, cooling system flush, heater core backflush... and finally found my damned leak, too. It was the heater hose next to the water neck. I didn't buy new heater hoses because I'm leaving them be until I do the heater core along with the dash... oh well. Hacked off the leaky end, all's well.
The heater is back to kicking wicked *** now, just in time for winter. The forecast has snow for Tuesday/Wednesday, overnight low of 12 degrees (F) Wednesday. Yay for heat!
  #5875
Old 10-23-2011, 08:03 PM
dsertdog56's Avatar
dsertdog56
dsertdog56 is offline
This picture is worth a thousand words and none of them are printable
  #5876
Old 10-24-2011, 02:30 PM
TheBrownDragon's Avatar
TheBrownDragon
TheBrownDragon is offline
Replaced a burned out headlight and bought some pb blaster for my manifold bolts. I need to do the plenum since the magnet sticks. I havent lost power but it uses oil. When I got in there, bolts looked new. Maybe the last guy just did the gasket and not the plate, oh well.
  #5877
Old 10-24-2011, 07:53 PM
BackwoodsRam
i did a steering gearbox adjustment, and shopped around for places to install a set of gears. luckily my dad know a guy that might do it all for 300 total if i buy the parts
  #5878
Old 10-25-2011, 12:01 AM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
Damn I ran those tires and put them through pretty much everything but rock climbing.....how the F^ck did you manage that
  #5879
Old 10-25-2011, 01:06 AM
kfbryant1's Avatar
kfbryant1
kfbryant1 is offline
Drove my 99 with 180K 500+ miles home today.. To UnRegistered, I lived and worked in Meeker in 08! It was a very cool place and the folks there were GREAT!
  #5880
Old 10-25-2011, 08:45 PM
dsertdog56's Avatar
dsertdog56
I would guess that it was combination of dry rot and the rock crawling, bouncing off stuff. But mostly dry rot.
These tires are 6 years old just past the day. For that last 4 years I probably put less than 1500 miles a year on it. They've see a lot of southern heat. I don't believe that preservatives helped but I believe they may have sped along the process.
Quick Reply: What Did You Do To Your 2ND GEN RAM Today?
