The Official 2nd Gen RAM Forum OT thread
Old Apr 4, 2013 | 12:46 PM
  #8141
Google actually does a better job than the search engine here, is much more powerful, and less restrictive. You can structure your search such that it only searches dodge forum as well:
search terms site:dodgeforum.com
Google to search DF?? I never heard of such a thing.....
Look what I found: https://dodgeforum.com/forum/2nd-gen...00-shocks.html
Old Apr 4, 2013 | 12:59 PM
  #8142
stewie01's Avatar
stewie01
It's either hailing or raining little ***** of ice, I'm not sure which yet.
Old Apr 4, 2013 | 01:06 PM
  #8143
It was sleeting here in High Point a little bit ago....April 4??? WTF??!!
Old Apr 4, 2013 | 01:12 PM
  #8144
redneck_ram's Avatar
redneck_ram
snowed here on tuesday. just a squall, but it was 43 out....
Old Apr 4, 2013 | 02:09 PM
  #8145
stewie01's Avatar
stewie01
Sleeting now
Old Apr 4, 2013 | 02:49 PM
  #8146
dlyter09's Avatar
dlyter09
Its about 53 here and sunny
  #8147
aofarrell2's Avatar
aofarrell2
Sunshine and 65* here . Might get my trans pulled today too.
Checked the specs of the Ford against those of the Dodge:
Dodge 360 (stock):
HP: 235
Torque:330 ft/lb
Ford 460 (stock):
HP: 245
Torque: 400 ft/lb
Dodge 408 stroker (360 based):
HP: 300-400, depending on aspiration and cam
Torque: Up to 500ft/lb (depending on cam and aspiration once again)
Ford 590 stroker (460 based):
HP: 800 naturally aspirated, 1200+ turbo'd and 80lb injectors
Torque: 650 ft/lb
Correct me on the Dodge numbers if I am wrong, stock numbers for both engines are from my vehicles. Both systems seem to show up to 30rwhp on a stock setup with proper tuning.
Now it gets really interesting:
On the Ford 460, on a stock displacement, with a less restrictive cam, tuning,and true dual exhaust without catalytic converter, MAF wideband sensor system (MAP sensor is changed to a MAF sensor, O2 sensor is replaced with wideband sensor), and dual ram-air cold air intakes, the 460 can make a impressive 30MPG. Highway of course. But here's where it gets really interesting: The Ford EEC-IV system allows for tuning through chip burning. The chip most people use has a 5-position switch on the dashboard. One position allows the default EEC programming to run the engine (and tranny, if auto), and the other 4 are custom tunes by the person. This allows for a person on the fly to switch between tunes, without needing to stop and reflash, unlike most other OBD1 systems, and many OBD2 systems. So one of those four is high-MPG tune, for simply highway no-load driving, then maybe another one is the high-power tune, pushing 350RWHP with the above listed mods. Easy. And no high-octane fuel needed even with extreme timing if a proper distributor kit is used.
So my question is: If a bigger much heavier system can get 30MPG, why can't the Dodge 360 get 30MPG? Ford didn't even use a really steep O/D to attempt to boost fuel economy like Dodge did. Any ideas? And no this 30MPG thing is no BS either, so don't try to call BS.
So I'm trying to puzzle this together now... I wonder if it's the computers, or what
Old Apr 4, 2013 | 02:55 PM
  #8148
dlyter09's Avatar
dlyter09
What the hell ford is getting 30mpg??? Id love to see the specs and proof of that.
Old Apr 4, 2013 | 04:13 PM
  #8149
stewie01's Avatar
stewie01
Old Apr 4, 2013 | 04:51 PM
  #8150
~moparlove~'s Avatar
~moparlove~
Has anyone ever heard the old wives tale about when you start your car, to let it sit for 10-15 seconds before actually driving it? I remember my Dad saying that when i was little. He said thats supposed to be the ample time to let the oil get to where it needs to go before you start driving conditions. Ive always done this but wondered if anyone else does it or if you really dont need to. Or maybe Im just paranoid and a creature of habit haha
