Ram Body work
Old Jul 12, 2012 | 04:45 PM
  #551
dlyter09's Avatar
dlyter09
Are you leaving the emblem dark like that on the grille? Or are you planning something else for it?
Old Jul 12, 2012 | 04:56 PM
  #552
Wombat Ranger's Avatar
Wombat Ranger
WOOT!
Old Jul 12, 2012 | 07:35 PM
  #553
stewie01's Avatar
stewie01
What emblem? There isn't one there....
Old Jul 12, 2012 | 07:53 PM
  #554
dlyter09's Avatar
dlyter09
pffttttt... i know this.....
Old Jul 13, 2012 | 01:11 PM
  #555
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by gdstock
Here it is...the pick of front - that is not a chip off the paoint on bumper trim. Gave me a coronay. It was water from topping off radiator and washing under hood!
Have a slight stripe alignment issue on trim, but it is fixabel....Saturday...
Hey now.....it's actually looking like you don't work on it anymore and actually drive it.
:thumbsup:
Old Jul 13, 2012 | 01:28 PM
  #556
Girly TT's Avatar
Girly TT
are you wetsanding/finish sanding with an orbital sander...??
Old Jul 13, 2012 | 11:35 PM
  #557
gdstock's Avatar
gdstock
I got piece for that on e-bay, but it is about 1/2" too big. I think it from a newer truck. Looking for another and wanting to stay away from dealer, but may price check there tomorrow.
Also need to reinstall third brake light and tailgate handle,
:thumbsup:
Still have some work. A little touch up, flipping the hood and painting underside, as it looks "dirty" when the hood is up. I painted inner fenders and other areas in engine bay when I installed e-fan, so th under side of hood is the worst part now.
I drove to Austin Thursday and back home this evening (about 200 miles each way). Ran like a top. Got lots of looks - e-fan does have a distinctive sound....and with AC running, the fans run at 100%. Driving home in the rain with outside temp about 84, engine was running about 160 degrees. Anyone know at what point one should expect to see adverse effects of low temp? Watching AF gauge, it appears to have about the same range of motion as any other time. Also trans temp ranged from 150 to 106 degrees.
Dry with 1000g with orbital, then wet with 1200 grit 3M purple. I did not sand the hood yet as I ran out of time. Had to slap hood and tailgate on Thursday afternoon for trip out of town for work. I hope to sand and buff it Saturday. I have a couple small places where I think I buffed too much as the shine started to dull. Gotta figure out how to fix those. Wish there was a better way to learn this instead of trial and error....but....
Then it will be time to spray bedliner, weather permitting.
Old Jul 14, 2012 | 07:36 AM
  #558
Girly TT's Avatar
Girly TT
That is why you keep burning through the paint. finish sanding, is a wetsand by hand, NEVER with a power sander. If the finish is that bad (orange peem, runs, etc), wetsand witg 600 grit, then go over it with 1000 grit, then buff. Never ever ever with an orbital or any power sander. That is for prep work only.
Old Jul 14, 2012 | 08:42 AM
  #559
kejobe's Avatar
kejobe
You can finish sand with an orbital as long as you have a foam pad. Its about ½" thick and attatches to the pad of the sander. It helps prevent any "hard" spots when sanding. It does not do much of anything for a smooth finish though. It will give an OEM look (slight orange peel). In other words, these are used more in collision shops (seen and used them) than custom (never seen or used) and Ive worked in both.
Old Jul 14, 2012 | 08:46 AM
  #560
kejobe's Avatar
kejobe
BTW, GD, lookin real good!
