Your Plenum Gasket Pictures -- Post Up
Old Sep 16, 2012 | 03:06 PM
  #101
cruzer55's Avatar
cruzer55
I rid myself of the problem,replaced with M-1 intake.much better!!!!!!!!!!!
Old Sep 16, 2012 | 03:15 PM
  #102
95RAM360's Avatar
95RAM360
Originally Posted by It's Me Patt
That's looks awesome! What type of gasket came in your kit/did you use?
Hughes plenum kit...it comes with a felpro gasket and says not to use rtv...i didnt and mines still clean inside...been just about two years now
Old Sep 16, 2012 | 03:19 PM
  #103
It's Me Patt's Avatar
It's Me Patt
odd, huhges sent me the VR kit and it said to use RTV in the four corners..guss I see how it goes...
Old Sep 16, 2012 | 03:53 PM
  #104
I think they meant not to use RTV on the plenum gasket, the four dabs in the corners of the intake gasket, where they meet the valley end seals, or just about a requirement.....
Old Sep 16, 2012 | 04:15 PM
  #105
It's Me Patt
got ya..that's what my SM said to do also..I see some guys don't even use cross over gaskets, just RTV or something..there's so much meat & metal I can't see not using them..but if it works so be it..
Old Sep 17, 2012 | 09:59 AM
  #106
Sometimes, if you mill the block/heads..... there just isn't enough clearance between the block, and intake manifold, for the end seals to stay in there, so, they squeeze out fairly rapidly..... Chevy small blocks are notorious for that.. I don't see why mopars should be any different.
Just using a nice bead of RTV works just as well, and compresses nicely as you torque the manifold. Bit more forgiving than the hard rubber seals.
Old Sep 17, 2012 | 02:14 PM
  #107
zman17's Avatar
zman17
Retired Moderator - RIP
I highly suggest using the cross over gaskets. Use rtv in all 4 corners and a very thin coat on the cross overs(both sides) and around only the coolant ports. And the Hughes plate only comes with that thin metal plate gasket and a Victor Renz intake manifols gasket, which I am going to try next job as opposed to the felpro plate gasket.
And make sure the the dimples/ **** or whatever you want call them are cleaned out. Look at the NEW crossover gaskets. They have **** that need to go into the holes on the block surface.
Old Sep 24, 2012 | 01:11 PM
  #108
crazzywolfie's Avatar
crazzywolfie
i pulled one off a 94 at the junk yard and it looks like it was blown in 2 spots. all the intake bolts came off easily. only ran into 2 problems while removing it. the 1 head broke off one of the bolts into the a/c bracket which forced me to snap the aluminum bracket and the tube from the exhaust to the intake. had to break that one by moving the intake around a lot. now i can clean and fix one intake so that i will have almost no down time. just wish the throttle body had still been on it.
Old Nov 11, 2012 | 09:03 PM
  #109
Wh1t3NuKle's Avatar
Wh1t3NuKle
bump for edjimacation and stuff.
Old Nov 11, 2012 | 09:29 PM
  #110
I'm still confused about where to put rtv.
