Need better MPG
Old 01-13-2012, 08:58 AM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
Originally Posted by Ugly1
I run an exotic blend of about 78% nitrogen, 20% oxygen, and the last 2% a mixture of water vapor, CO2, trace hydrogen and various noble gasses.
I'm using essentially the same exotic blend and can report that it works very well. I have a little less water vapor than most, thanks to rigging my compressor so its intake is on the Western Slope of the Rockies.
And, gosh, if that whole goofy "bigger molecules don't leak out through the pores" thing is a significant factor, then over time I'll end up with a greater proportion of bigger molecules in there. Bonus!
  #22
Old 01-13-2012, 05:19 PM
Ramcountryboy's Avatar
Ramcountryboy
Ramcountryboy is offline
Works pretty well as long as the pressure is regulated well at the optimal level.
LOL! That was pretty good
  #23
Old 01-13-2012, 05:42 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,273 Likes on 3,020 Posts
Its' the noble gases that reduce rolling resistance.......
  #24
Old 01-13-2012, 06:01 PM
grox's Avatar
grox
grox is offline
I estimate that you may actually have an even higher nitrogen concentration, since the nitrogen molecules leak more slowly than your exotic blend does in general (according to certain claims that nitrogen filled tires hold their pressure longer). So over time the nitrogen concentration would build-up.
  #25
Old 01-13-2012, 06:54 PM
KxRideRon125's Avatar
KxRideRon125
KxRideRon125 is offline
wait so u can use nitrogen to fill ur tires or is some kinda joke that im to retarded to get...
  #26
Old 01-13-2012, 06:55 PM
HeyYou is offline
You can, but, it doesnt really make any difference. Hell, you could use CO2 to fill your tires.... but, it still leaks out.
  #27
Old 01-13-2012, 07:14 PM
chadhager03's Avatar
chadhager03
chadhager03 is offline
Fill em up with helium so it makes your truck lighter that'll net you a couple mpgs
  #28
Old 01-13-2012, 07:16 PM
Mutt Bryant's Avatar
Mutt Bryant
Mutt Bryant is offline
Haha just throwin an idea out there. I ain't tried it so I have the same exotic blend as the rest of you. But anyways, a light pedal foot does help alot.
  #29
Old 01-13-2012, 07:27 PM
97black_ram's Avatar
97black_ram
97black_ram is offline
ok so ive seen other threads about getting better mpg..but the other threads i see the people wanting more already get around 11-12..i got a spectre air filter and a glasspack and the rest is stock and i get around 9-10. Whats wrong, i do all my tune ups when im suppose to. ANY ideas 5.9 engine
Same mileage I get. Running 265/75/16 tires, plenum fix, upgraded cap and rotor and wires, spectre filter, 3.55 gears, etc. I got 197,xxx on the engine and the 10-12mpg's hasn't changed since I got it at 115k. Look on the bright side the 4.7L and hemi's are not doing any better and our trucks are 10+ years older.
  #30
Old 01-13-2012, 07:36 PM
HeyYou is offline
I like the way you think.
Didn't the newer trucks have some variety of variable displacement? Shutting down a cylinder or three when not needed??
