Bullspit!!!
Old Feb 7, 2012 | 05:14 PM
  #21
BigBlue83's Avatar
BigBlue83
zman: not sure how much of the post you read but i mentioned that earlier that i was going to spend money on new wires plugs rotor and cap when doing my plenum i recently received but due to recent events should i drop the pan replace filter solenoid and adjust bands??? thats when i mentioned the crap on the dip stick... (oh and doing the check valve elimination as well
Old Feb 7, 2012 | 06:27 PM
  #22
zman17's Avatar
zman17
Retired Moderator - RIP
I'm willing to bet the Gov solenoid is clogged again. Which obviously is not a good thing. Drop the pan again, and clean it, and see what happens. Just trying to save you some money short term, so you can save for up for a new tranny.
Edit: Sorry, By "clean it" I mean the Gov solenoid.
Old Feb 7, 2012 | 06:32 PM
  #23
stewie01's Avatar
stewie01
Originally Posted by Wh1t3NuKle
Kinda missed post #12 eh?
It wasn't there when I posted my comment! That's my story and I'm stickin' to it
Old Feb 7, 2012 | 06:42 PM
  #24
BigBlue83's Avatar
BigBlue83
yea i was thinking of that. ive read that screwy shifts can come from the solenoid because if the screen gets clogged like the filter gets clogged acting as if it was low fluid because it cant get flow properly. im torn between buying the tranny for around hundred bucks than starting to get all the rebuild stuff over the next two weeks and start doing the tare down and rebuild with in the month and just hope my tranny holds on till the new one is rebuilt. or spend the hundred bucks on trying to save this tranny.
Old Feb 8, 2012 | 06:24 AM
  #25
BigBlue83's Avatar
BigBlue83
well i slept on it, and im going to drop the pan and inspect the fluid, the magnet and gov. pressure solenoid. going to do it this weekend, i know i can do the job fairly quick, ive dropped and changed several tranny pans and filters, however i want all the light and time, im going to check all lines wires going to the tranny and clean the outside with brake cleaner. if it doesnt fix it and the guy still has the tranny than next weekend i will buy the used tranny tear it down clean it all up over the next couple weeks and rebuild it. the only worry is maybe he wont have the tranny anymore. its the only one in my area, however worse comes to worse im just going to have to pull mine. Ill buy a ****ing peddle bike and bike into work for a month use my money i would have spent on gas for my rebuild. (its a little cold though lol)
the most frustrating part is dealing with a bitching wife
Old Feb 8, 2012 | 09:50 AM
  #26
Wh1t3NuKle's Avatar
Wh1t3NuKle
Big bro, you know what is a week from yesterday, right?
Just sayin' in case of potential priority assessment for mind, body, souuuuuuuul.
Old Feb 8, 2012 | 09:53 AM
  #27
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by safrantz
find your closest harborfreight, buy the tools and make it happen! may be able to offset some of the costs if you get some tools that friends need or people you know need and get a small service charge for using your new tools! e.g. the press!
You're advising he buy tools at Harbor Freight?? Geez, why don't you torch his house while you're at it?
Old Feb 8, 2012 | 10:02 AM
  #28
drewactual's Avatar
drewactual
ask purpledodge how that harbor freight torque wrench worked out for his transmission..
OP: keep your head up dude, you're BigBlue-MF'n-83... you ain't pray, you is the predator.. so what? you get some curve *****, so the ef what? you've hit em' before, and you'll hit these too- stop playin' with yourself acting all like "I'm effed", because you ain't effed- you know it, and so do we.. you is just acting all pissed and down to feel mortal.. eff that.. fix your shizen and shut up!!
btw- it certainly sounds like a solenoid.. the questions I would have, is why so soon? the little test you can do is shift manually.. drop the lever past D to first from a stop- accel to suitable speed, manually shift to second.. then D.. ect.. if it does this without complaining, your electronics (solenoids) are jacked, and not your transmission proper..
Old Feb 8, 2012 | 11:09 AM
  #29
BigBlue83's Avatar
BigBlue83
ill try the manual shift as far as why so soon what do u mean? Ive never done the solenoid since ive had my truck and I highly doubt that the P/O did it
Old Feb 8, 2012 | 11:14 AM
  #30
Gary-L's Avatar
Gary-L
Veteran: Navy
oh.. I misunderstood.. I was thinking it was you who did this not long ago.. those things get gunked up.. it happens.. if i were to clean one, or replace one, and have to do it in short order? I'd be wondering where all that gunk came from.. that is why i mentioned it..
The gunk forms because the transmission filter and fluid are not being changed on a regular schedule.
