Bullspit!!!
Old Feb 11, 2012 | 04:16 PM
  #51
gdstock's Avatar
gdstock
OK. I see part of your problem. I had the same thing.
There is a strut that is about 1 1/4" long and about 1" wide and 1/8" thick that sits in a notch in the arm to the servo and rests on a fitting on the rear band. It fell out of place allowing the servo arm to drop like that. The servo cannot reach that to engage the rear band.
Reach around beneat the band on top of VB. It may be resting there just out of sight. It is a PITA to put back in...
Old Feb 11, 2012 | 04:42 PM
  #52
BigBlue83's Avatar
BigBlue83
o.k so im kinda lost lol. i take it the band in the video was not supposed to move like that thats why you posted a pic of your band hanging like that.
I dont know what the servo is. I know vb is valve body, i will look at the service manual to find location of of valve body so i can look for the strut you mentioned. any more info would truly help. Thank you
Old Feb 11, 2012 | 05:18 PM
  #53
gdstock's Avatar
gdstock
See the adjusting acrew in the photo I posted? It should be right above that on the VB if it is not in the pan. The servo is the piston which is operated form hydraulic preesure forn the pump. When it pressures up, the piston moves down and osuhes on the rod on the arm, moving it downward and then pushing on the strut to close and hold the band clamped on the drum.
Old Feb 11, 2012 | 06:54 PM
  #54
BigBlue83's Avatar
BigBlue83
ok, so ive read portions of the service manual, and found out that the vb is not what i thought it was, thats why i didnt know where it was, that **** was right in my face lol. i also googled and googled until i found the piece i believe youre talking about. its kinda dark but i went out with my flash light and took a look i didnt see anything or feel anything. Not too insult you gdstock, but im not too confident in what im doing are you sure the piece you said is moved or missing is truly not where its supposed to be?(i know my video wasnt the greatest) (nor my pic of the vb with the filter off) as i said i dont know too much of what im doing. any ways would it be recomended that i remove the valve body and search for this piece??? in the morning i will get a better look. here is a pic of the piece i believe you are talking referring too
in the mean time im going to take my time and read i big portion that i havent read yet in the service manual, and try to determine where this mysterious strut is supposed to be.
heres another picture
Old Feb 11, 2012 | 07:52 PM
  #55
BigBlue83's Avatar
BigBlue83
so after a couple mins of reading and searching i went out to my truck with a flashlight to take a look. What i believe is the front band (i know thats the one you adj from the outside of the tranny) has the strut, still not sure of the location of the rear strut
here is a pic of the front band strut
Old Feb 11, 2012 | 09:28 PM
  #56
gdstock's Avatar
gdstock
The strut for the rear band that you are looking for is this one:
http://i1096.photobucket.com/albums/...lue/strut2.jpg
IU looked for a photo that I took, but it must be on another computer.
Old Feb 12, 2012 | 08:58 PM
  #57
Augiedoggy's Avatar
Augiedoggy
Originally Posted by BigBlue83
AUGIEDOGGY: off topic but do you remember that pm i sent you regarding the hi flow cat and pipes? well i found the part number you sent me, however it said it was for a 6 cylinder. I have an 8
magnaflow 23285?
here's the link to the one I bought...I have a 5.9.
http://www.ebay.com/itm/170637143204...84.m1497.l2649
I would spray the crap out of that soleniod and reinstall it...there is a DIY on how to dissassembe it and clean and test it in the DIY section...I did try it and it seemed to work but I replaced with the borg warner unit when I had mine rebuilt... tranny shop said when they plug up bad like that usually something else is failing which makes sense... my TC failed and plugged my valve body passages...
Old Feb 13, 2012 | 12:36 PM
  #58
BigBlue83's Avatar
BigBlue83
Just an update. Going to remove valve body this week. Today is too frigid supposed to get 40 degree weather tomorrow so may cut outa work an hr ealy to remove vb and inpect/clean it up. see what happens from there
Old Feb 15, 2012 | 11:27 PM
  #59
Dougp63's Avatar
Dougp63
Hi, just read your post... I feel your pain! I had a very similar problem only the anchor for the front band broke! I found it resting on top of the valve body. I bought a new HD one along with a HD strut. It wasn't too bad to put in, but I had to drop the VB. This is on the second trans I put in within 500 miles. STAY AWAY from those rebuilt trans on E-BAY from a guy in Hawley PA (Not going to say the name of his company...). They are CRAP! Now I am getting a TCC code.
Old Feb 16, 2012 | 08:33 AM
  #60
Augiedoggy's Avatar
Augiedoggy
I seriously considered an ebay transmission but without any real warranty and being so close in price to the local shop who did all the work I decided against it...I realize all sellers are different but something like this just seemed like more of a risk.
