building a most fuel economic ram 1500 5.2L
#151
hey guys just woundering if you had any tips for me on how to get better gas milage out of my 99 dodge ram 1500 4x4 sport i have flow master 60 serious with a magnaflow cat. A k and n air filter and a hypertech eco boost i get 13.5 mpg now. the truck is all stock original motor and tranny has over 218xxx miles on the truck. Please help and thankyou vert much will post pic soon.
#152
#155
#157
#158
hi guys, my transmission broke during test drive. i managed drive back with the truck in second gear and almost stop on slop. droped the oil pan no burns or broken parts, i took off the valve body dissaseemble it found the gorvenor pressure piston spring broke in 3 pieces, lucky i found a new valve body cheap in ebay, what cause the spring broke? i knew is not temperature, because it broke just after my truck exited highway drive and happened in couple blocks of local drive. i have change the pressure solenoid to a borg wagner upgrade one because of the late shift, it works. i also put 2 lucas tranny fluid in .the first band has lot of freeplays ,but not burn. what you suggest,?put back the borg wagner solenoid or just put back the oem valve body and do nothing.
