redneck_rams 360 build thread
Old Mar 22, 2013 | 03:01 PM
  #391
redneck_ram's Avatar
redneck_ram
Originally Posted by stewie01
I'd bet techjockey has one
good call... forgot he did the swap lol
Old Mar 22, 2013 | 03:06 PM
  #392
stewie01's Avatar
stewie01
How much of a b!tich is it to remove?
Might be something zman encounters on his junk yard runs too....
Old Mar 22, 2013 | 03:14 PM
  #393
redneck_ram
pretty easy actually but its on the trans, so you have to get on the ground...
Old Mar 22, 2013 | 03:57 PM
  #394
redneck_ram
wooooooo hooooooooo found the bushing!!! hopefully that solves my slight shifter issue!
Old Mar 22, 2013 | 04:50 PM
  #395
redneck_ram
ok, small problem... park, is reverse. reverse, is neutral. neutral, is drive, and so on...
how can i fix that? i found the bushing for the torque rod, as i stated in an earlier post.
HELP!!!!!!!!!
Old Mar 22, 2013 | 05:19 PM
  #396
dlyter09's Avatar
dlyter09
Your indicator on the dash showing that? Or is it actually like that?
Old Mar 22, 2013 | 05:41 PM
  #397
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
If you look at the linkage on the engine firewall going down to your tranny their is a clamp that you can loosen up and adjust your pointer to be in the correct place. So what you do is put the truck in park, loosen clamp, adjust so pointer is in park, retighten clamp and try it out to make sure it works properly.
Old Mar 22, 2013 | 05:52 PM
  #398
redneck_ram
its actually like that. shift inficator is showing.the right gears but the transmission is arguing it. with the shift lever in park its in reverse meaning i cant start my truck... kinda sucks...
Old Mar 22, 2013 | 05:54 PM
  #399
redneck_ram
good advice! gonna try that when i get home. hopefully tjere will be enough light still. if not ill do it tomorrow morning.
Old Mar 22, 2013 | 06:08 PM
  #400
dlyter09's Avatar
dlyter09
You can start it in neutral... But What wildman said should work for you.. There is also a pointer adjustment behind the knee panel under the wheel.. If that isnt the one he is talking about.
