redneck_rams 360 build thread
Old Mar 22, 2013 | 06:34 PM
  #401
woods4life's Avatar
woods4life
I really regret not making a post like this for mine, seeing as i just did it a week before. I only have a couple pics of the motor coming out and my nasty transfercase
Old Mar 22, 2013 | 06:51 PM
  #402
redneck_ram's Avatar
redneck_ram
Originally Posted by dlyter09
You can start it in neutral... But What wildman said should work for you.. There is also a pointer adjustment behind the knee panel under the wheel.. If that isnt the one he is talking about.
no its definitely the one wildman's talkin about. i knew about the needle adjustment on the column. kinda hard to miss it when changing the heater core lmao!
i got the truck in park now, and will adjust the rest of it tomorrow. starting to lose light, and its getting cold. started snowing again WTF! only flurries though(thank god!).
she sounds soooooooo good when revving her up. cant wait to get the custom tune installed, so i can really give it to her....
Old Mar 22, 2013 | 07:57 PM
  #403
zman17's Avatar
zman17
Retired Moderator - RIP
So what about extending the o2 wires? I actually have a couple old ones we can use the wires from.
Old Mar 22, 2013 | 08:02 PM
  #404
redneck_ram
i need to get the rest of my pics uploaded, and my buddys gonna take another video with it driving/doing a burnout(aka one tire fire)
i have plenty of wire, neighbor has a soldering gun, and solder. just need to get some heat shrink.. for now its disconnected...
Old Mar 22, 2013 | 08:07 PM
  #405
zman17's Avatar
zman17
Ok bud, don't forget the grease and the liquid tape. Just solder and shrink wrap isn't going to last.
Old Mar 23, 2013 | 07:15 PM
  #406
redneck_ram
hmmmm... well i havent driven it since yesterday, now i need to get another new bushing for the rod that comes down from the steering column.
i set fuel sync to 0 tonight, because it was jumping from 6+ to 8+... but theres an issue. at times when im revving the motor it will backfire through the throttle body. firing order is correct, fuel sync is jumping from -1, to +1. so thats spot on.
any ideas? its very strange! could it be a tune issue?
Old Mar 23, 2013 | 08:32 PM
  #407
gdstock's Avatar
gdstock
Was it backfiring before you change fuel synch?
Old Mar 23, 2013 | 08:36 PM
  #408
redneck_ram
yeah, i think so. more so then, than now.
Old Mar 23, 2013 | 09:09 PM
  #409
gdstock's Avatar
gdstock
Only other thing I can think of (long shot) would be if CPS is secure. But then again, I think you would see erratic fuel synch.
Is you Snap ON a MT or MTG? If MTG, maybe graph fuel synch while ruunning and backfire to see what it looks like, then same thing with upstream O2.
Old Mar 23, 2013 | 09:15 PM
  #410
redneck_ram
no, its only the mt2500... i wonder if i swap out the pickup from the 5.2, if that would work.
also, i just remembered... there was one wire on the upstream o2 that had a portion of bare wire by the base of the sensor. would that cause a problem?
