snowboundrmk's 360 build
Old Sep 24, 2013 | 03:29 PM
  #71
RPMRamFury's Avatar
RPMRamFury
Yes I am.
  #72
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
LOL
Small world, eh?
Old Sep 25, 2013 | 07:40 AM
  #73
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Originally Posted by snowboundrmk
Well I got all the pistons in but when I torque the #8 rod cap to the 45lb spec the engine locks up and becomes impossible to turn over. The clearance is in spec so I'm gona mess with it some more tomorrow and try to figure it out.
I will guess you've got some caps & rods mixed up. Ask me how I know this? Because I did the some thing not too long ago. I would have sworn I had done a awesome job not getting the caps & rods mixed up but sure enough I did. As merc said make sure you've got the chamfered side going the correct direction and also look to make sure you've got the caps & rods with the correct one.
Old Sep 25, 2013 | 11:53 AM
  #74
snowboundrmk's Avatar
snowboundrmk
Sounds like a good idea. I never did check the rods with the caps. I just put the numbered caps on the right journal and figured the machine shop put them with the right rods.
Old Sep 25, 2013 | 12:50 PM
  #75
merc225hp's Avatar
merc225hp
Left it to the machine shop.... not good. One should always mark the cap and rod on the side with a corresponding number before taking it apart, this keeps them as a matched set. You match the numbers up to the same side and then install the pistons/rods/caps.
Old Oct 1, 2013 | 05:44 PM
  #76
snowboundrmk
Ive been messing with it for a while and I think the the caps are mixed up. I used a micrometer and the journal was good so I looked at the rod and the cap hangs over the rod on the side the journal is on. So it's not a perfect circle. I wonder why no other rod would lock up when I torqued it then?
Old Oct 2, 2013 | 12:32 AM
  #77
snowboundrmk
Originally Posted by RPMRamFury
Yes I am.
How long did you have the truck for?
Old Oct 3, 2013 | 11:41 PM
  #78
snowboundrmk
Caps 6 and 8 were switched around. I did originally mark everything with a sharpie and the machinist punched it for me. He must have read it wrong, but anyways it spins great now.
Old Feb 21, 2014 | 10:45 PM
  #79
snowboundrmk
I'm finishing up my list of parts to order, and I was wondering what double roller timing set to get. I found this mopar one, but I can't find the cloyes one everyone seems to have.
http://www.summitracing.com/parts/dc...iew/make/dodge
Old Feb 22, 2014 | 12:03 AM
  #80
Ham Bone's Avatar
Ham Bone
I have the Mopar one and am completely happy with it
