New help 97 dodge ram 1500 2wd lifts questions
Old 01-03-2015, 11:53 PM
97dodgeramlover's Avatar
97dodgeramlover
97dodgeramlover is offline
Post New help 97 dodge ram 1500 2wd lifts questions
Hey I have a 97 dodge 2wd and I just bout a 3 inch front and 2inch rear lift kit and I was wondering what kind of problem I'm gonna run into and tire size because I have set of 285/75/16 on it now and it rubs verylitte on left hand turns I was thinking if a set if 35 but idk and how hard would g it be to put the lift in myself or should I get someone else to?
Old 01-04-2015, 10:19 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,270 Likes on 3,017 Posts
3 inches on a 2wd might be too much for your ball joints. if the kit is from a decent company, they may mention that in the install instructions......
You are going to need at least 5 inches for 35's, and on a 2wd, that means things like new control arms, and such.
Old 01-04-2015, 04:23 PM
97dodgeramlover
Ok and I no I'm gunna need new front and back shocks do I no what size I will need?
Old 01-04-2015, 05:56 PM
Johnn123's Avatar
Johnn123
Johnn123 is offline
3" lift shocks for the front, I have no idea how or if that would differ from a 4wd. Rear should be fine at 2". HY is quite right about it being a lot on your ball joints. If you want more lift look into a 3" body lift. That will give you 6" of lift. Clear 35's then, but you will definitely want to regear the rearend to 4.56... otherwise its a lot of unnecessary stress on the driveline.
For if you should install yourself or not, if you're comfortable and understand the front end, as well have the tools do it yourself. If not have a reputable shop do it.
What is this kit you bought?
Old 01-04-2015, 06:11 PM
97dodgeramlover
CARBON STEEL LIFT KIT COIL SPACER FRONT 3" REAR BLOCK 2" 2WD 4X2 U-BOLT
It's that one for $125 on ebay
Old 01-04-2015, 11:38 PM
Johnn123's Avatar
Johnn123
Johnn123 is offline
I found it, doesnt look bad for $125. Just remember 3" might be a bit much for the ball joints and such.
Old 01-05-2015, 04:52 PM
97dodgeramlover
Yea it shouldn't be a bad kit it can to $246 shipped to my door all I need now is shocks and I looked it up and the ones I have on now are 10 front and 18 inches rear so I think 4x4 shocks will work
Old 01-06-2015, 09:29 AM
Johnn123's Avatar
Johnn123
Johnn123 is offline
If you havent ordered anything Id suggest just getting a 2" level for the front and a 2" AAL in the long form. 3" spacers just seem sketchy to me. You wont really notice 1" of lift different. If you go that route you dont have to worry about shocks then.
Old 01-06-2015, 09:31 AM
97dodgeramlover
No I already ordered it does anyone no how long of shocks I will need in the fr
97dodgeramlover
In the front
Quick Reply: New help 97 dodge ram 1500 2wd lifts questions
