Who has owned their Secondgen the longest?
We bought our 95 in 2014. My father in law was the original owner of it though. It's back to being mechanically sound now except needing new rear shackles. I want to build a garage before I start body work. I'd like to build a rear bumper and fix the A/C this summer. Right now the electric fans are controlled with a temp switch from a 1990 camaro. Once I fix the A/C I'll install the Dakota Digital controller I bought so the fans come on with the A/C. I might get a set of shorty headers and dual exhaust also.
Bought mine in 2014. Fighting the rust cancer too. I'm going to try to fix mine though before it gets too bad.
And I'm starting to get a bunch of rust on the bottoms of the door panels. I already wire-brushed and treated the driver's side with rust inhibtor to delay the rot until I can properly repair it, but I really need to hurry up because the passenger side is getting a lot worse now. My plan is to wire brush all of the rust away, apply rust inhibitor, smooth with Bondo as necessary, and then apply Monstaliner up to the door moulding. Hopefully that will put an end to it. The rest of the body/frame is in great shape, with the exception of several minor dings and dents from 14 years of service as a work truck. The clear coat is starting to peel on the roof and bed rails...maybe I'll coat those areas with Monstaliner, too.
Yeah, I hit all the rust on my rocker panels / quarter panels a few years ago with a wire brush and got all the rust cleaned up, applied POR 15 and painted over it with silver spray paint. Those panels have rusted through now, seems like it comes from the inside out. I'm looking at replacing the panels on my truck.
Thansk! When you did your panels, did you feel like you had a lot more fitting to do than you would have if you had gotten a more expensive set?
