Possible dumb question???
Old Aug 9, 2015 | 08:25 PM
Hedrock's Avatar
Hedrock
Default Possible dumb question???
I have done a what I feel is a fairly thorough search and have had no luck with my question so here goes...
I have a 98 2500 4x4 and it appears to have a 5" lift (block under rear leaf) with 315/70/17 tires. What I'd like to do is be able to lower it back down so I can put smaller tires back on and it not look like a clown truck. The issue that I'm having is that any OEM coil spring that I find seams to measure close to what I already have on the truck now and I can't figure out how to lower the front end. The reason for the lower is to pull my travel trailer and not have to change gears. The trailer weighs 7400# dry. The truck will pull it but not down the high way very comfortably. Thank you guys for any help you may be able to provide.
Not my truck but I like how it sits.
Old Aug 9, 2015 | 10:44 PM
That five inch block is stock.
What gear ratio do you have in your diffs?
Old Aug 9, 2015 | 10:50 PM
Hedrock's Avatar
Hedrock
Not sure on the ratio. What ever was... is factory. Sure seems to sit high.
Brian
Old Aug 10, 2015 | 10:30 AM
Can you post a pic of yours?
Old Aug 10, 2015 | 08:28 PM
Hedrock's Avatar
Hedrock
Here's a pic...
Old Aug 10, 2015 | 09:19 PM
Spillage's Avatar
Spillage
Looks like stock 4x4 height to me.
Old Aug 11, 2015 | 08:07 AM
Moparite's Avatar
Moparite
X2!
Lowering the truck is not going to change that. Are you turning the overdrive off?
Old Aug 11, 2015 | 10:56 AM
Beautiful truck.... X3 on the 'looks stock to me'.
Old Aug 11, 2015 | 11:48 AM
LoneWolfArcher's Avatar
LoneWolfArcher
Nice looking truck. Love the tires. Those are 315s?
Old Aug 11, 2015 | 11:49 AM
LoneWolfArcher
I do have to say, it does look like the front was leveled. I wish mine had that stance, I am about 2" lower in the front.
