When i press on gas engine slows then revs up
Old Oct 23, 2021 | 11:22 AM
  #101
Yeah, I don't get that at all. It really *shouldn't* be doing that. Is it possible there is a short in that connector, and it makes contact when unplugged? Or something equally as silly? The PCM sees the correct reading for the TPS, at least, most of the time....... That's a real puzzler.
Old Oct 23, 2021 | 11:41 AM
  #102
Eddy67's Avatar
Eddy67
I just desoldered the wire right of the PCM and its reading 5.098
Old Oct 23, 2021 | 11:52 AM
  #103
If you unplug that connector, do you get continuity between those two wires? (unplugged at both ends.)
Old Oct 23, 2021 | 11:56 AM
  #104
Eddy67's Avatar
Eddy67
I just check it and there isn't
Old Oct 23, 2021 | 12:04 PM
  #105
Failing PCM?
Old Oct 23, 2021 | 12:25 PM
  #106
Eddy67's Avatar
Eddy67
maybe, I just checked the alternator its putting out 14.3 volts. The engine lite if off again
Old Oct 23, 2021 | 12:43 PM
  #107
You have an intermittent problem..... that's gonna be fun to find.
