Old Aug 7, 2015, 12:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine
Print Wikipost
Kegger Intake Mod DIY
Old Mar 2, 2011 | 11:03 PM
  #191
Ugly1's Avatar
Ugly1
It depends on what RPM your running, the condition of drivetrain, power delivery alterations due to mods etc. Need more info.
Old Mar 2, 2011 | 11:13 PM
  #192
ClubCab5.9's Avatar
ClubCab5.9
http://www.hughesengines.com/Index/p...r&partid=23044
Found this one surfing the www. Is this the samething you all are trying to do. Making the runners smaller and filling the intake in? What do you all use to fill in with? Is it worth the work?
Old Mar 2, 2011 | 11:24 PM
  #193
bdj5773's Avatar
bdj5773
I don't know about the RPM. Whatever is normal. I just don't want to waste my time doing the intake mod if not really any results to show for it.
Old Mar 2, 2011 | 11:32 PM
  #194
In and of itself, you probably won't notice a difference with or without the mod. What you WILL notice is that your truck runs better fixing that huge vacuum leak..... (and you will use less oil....)
The kegger mod doesn't do a lot by itself, BUT, it COMPLIMENTS subsequent mods. Bigger throttle body, headers, free-flowing exhaust, 1.7 rockers, SCT Tuner.... and whatever else you throw into the mix.
As it stands, the stock keg will limit gains from other mods, simply due to the long runners, and the limited amount of "space" available for the runers to draw air. Shortening the runners also has the effect of unshrouding them, giving the better access to the air volume in the plenum.
So, basically, if you don't plan on doing any other mods, kegger mod isn't worth the time. If, however, you have additional plans for your engine.... then, by all means, go for it.
I have a completely stock motor, aside from the kegger mod, I absolutley LOVE the way the engine runs now. I plan on eeking just as much out of the motor as I possibly can though, and this mod was free. Just took some time to do it up. Time is one thing I seem to have an awful lot of......
Old Mar 2, 2011 | 11:50 PM
  #195
bdj5773's Avatar
bdj5773
Here is what I'm doing this weekend: Plenum Fix, Timing Chain, Magnaflow CAT, O2 Sensor, SCT Tuner. Does this qualify for doing the Kegger mod or not? I will probably be getting the 1.7 rocker arms in a two or three months. Thanks.
Old Mar 2, 2011 | 11:56 PM
  #196
I would do it.
Old Mar 3, 2011 | 09:58 AM
  #197
bdj5773's Avatar
bdj5773
I would do it.
Do it I will then. I know it certainly can't hurt. It seems that having better air flow is always a good thing. Just the time factor I was concerned about if no real, meaningful difference. I've got a small air grinder which will make it go more quickly. Thanks.
Old Mar 3, 2011 | 10:38 AM
  #198
I picked up another manifold at the local scrap yard, and modified that one. Just transferred everything from my old one, to the new one when the time came. That way, I could take my time on modding the manifold, and still be able to drive the truck.
Old Mar 3, 2011 | 12:19 PM
  #199
tweeker909's Avatar
tweeker909
Havent seen anyone here copy hughes oem manifolds? I think its more of a "why your in there" type thing? Repairing the gasket that like's to leak n such.
IIRC the 7hp was on a 5.2? From what ive read the 5.9 responds much better to these mod's?
Old Mar 3, 2011 | 06:46 PM
  #200
atthewmartin114's Avatar
atthewmartin114
hey. i have a 2x4 single cab v6 3.9L Dakota it has the NV3500 5 speed. i understand this is the same tranny that is hooked to the 5.7L im thinking its much cheaper to build power with a 350. also i can get a vin change to over ride the OBD II being that its a 1997. (unless anyone knows someone that can shut off the monitors on the pcm. i believe the motor mounts off my 318 should work with a little mod. im looking for everyones input on this and info if anyone has done it.
