Oh where, oh where has my antifreeze gone???
Old May 27, 2008 | 02:43 PM
justneed2's Avatar
justneed2
Default Oh where, oh where has my antifreeze gone???
Alright, I'm stumped and need some help guys and gals.
My '99 Ram Sport is loosing antifreeze. The reservoir will be almost empty by the time I'm ready to fill up if I topped it off the last time I got gas.
There's nothing in the cab, no puddles under the truck, nothing in the oil - it's just up and vanishing. Okay, okay, I know it's not vanishing - but anyone have any ideas where it may be going.
I'm having a hard time tracking this one down, so I'm not sure what to fix.
Old May 27, 2008 | 02:49 PM
timsalas's Avatar
timsalas
Default RE: Oh where, oh where has my antifreeze gone???
grrrreat now i got that song stuck in my head LOL
U blowing white smoke? Done a compression test lately?
Old May 27, 2008 | 02:58 PM
justneed2's Avatar
justneed2
ORIGINAL: timsalas
catchy isn't it! haha!!
no white smoke, and I have never done a compression test on the motor since I bought the truck. - whatchya thinkin?
Old May 27, 2008 | 03:16 PM
Aubrey's Avatar
Aubrey
I would think maybe the heater core has a leak or maybe you've got a head gasket gone. If you crank the heat on high and by the time it heats up, do you smell antifreeze? If not, the core is probably ok. Does it ever run hot? Maybe on the highway at higher RPMs?
Old May 27, 2008 | 03:34 PM
justneed2's Avatar
justneed2
ORIGINAL: Aubrey
To be honest, I haven't used the heat in a while since the weather heated up around here. But I can try that tonightt on the way home from work.
If it was the heater core though, wouldn't I get some type of fluid in the cab on the floorboards?
As far as temp goes, I've been watching the gauges closely and all seems wel? - oil press. and temp.
1) to make sure that it doesn't overheat since i'm losing coolant, and 2) I figured in addition to being able to see coolant in the oil if it was there, that it would also make the oil pressure creep up due to increase fluid volume
Old May 27, 2008 | 08:00 PM
scottybme's Avatar
scottybme
my truck does the same thing. what is the compression supposed to be?
Old May 27, 2008 | 08:06 PM
padodgeram's Avatar
padodgeram
ORIGINAL: justneed2
I needed some for my truck...
Old May 27, 2008 | 08:36 PM
prospector's Avatar
prospector
intake manafold gasket is leaking into a cyl
Old May 27, 2008 | 08:38 PM
prospector's Avatar
prospector
just think what 160lbs of pressure would do to a rad
Old May 27, 2008 | 08:46 PM
aim4squirrels's Avatar
aim4squirrels
you are probably leaking onto a manifold and it's evaporating before you notice it. Do you have a split in the heater hose where they connect to do a backflush? I had a leak there due to a prestone "T" that you use to flush the heater core. I Had to tighten the clamps really tight to get it to seal. It dripped right onto the exhaust manifold and evaporated before I could see it.
