Trans Check Valve Delete
Old May 30, 2010 | 08:29 PM
  #101
truegent81's Avatar
truegent81
what does aux trans cooler look like? i know for sure i have 2 of the 3 up front
Old May 30, 2010 | 08:34 PM
  #102
On mine, it is between the condenser, and radiator, sorta at an angle. You can't really see all of it, lines just sorta disappear into the nether regions in there......
  #103
aim4squirrels's Avatar
aim4squirrels
There is no drilling involved. All radiators have a trans fluid heat exchanger. In the winter it gets the fluid to OP temp quicker. In the summer the coolant is supposed to be cooler on that side of the rad and takes heat from the trans fluid. I think that its still too hot. All rads should Have it though. Yours should as well.
Old May 30, 2010 | 10:02 PM
  #104
truegent81's Avatar
truegent81
lol. thats how i feel when i pop the hood and look at my motor with all these lines and cables...
Old May 30, 2010 | 11:05 PM
  #105
aim4squirrels
The aux cooler looks a bit like the power steering cooler, but a bit larger. If you have a big u shaped bracket that gets wider by the hood latch, it anchors to that. You can just barely see it if you shine a flashlight done there and look for it in the center between the rad and AC condensor.
Old May 31, 2010 | 12:19 AM
  #106
truegent81's Avatar
truegent81
i'll have to check tomorrow. i'll take some pics. is my factory setup fine you think?
Old Jun 1, 2010 | 05:09 PM
  #107
aim4squirrels
Running the fluid from rad to aux cooler to trans runs about 10* cooler than factory set.
Only time that might be a big problem is a cold winter snap.
Old Jun 3, 2010 | 01:46 AM
  #108
jtheshowstoppper's Avatar
jtheshowstoppper
so whats the benefit of deleting this check valve
Old Apr 18, 2011 | 12:02 PM
  #109
2000 V-10's Avatar
2000 V-10
Originally Posted by wingnut71
hi montec its me again lol i did the trans tuneup and it went fine but now i have the same problem i had and also now it doesnt want to shift from 1st to 2nd unless i let off the gas and then press it again kinda like using a clutch to shift and then it shifts but the sometimes it seems like it drops back into 1st and so on if it goes right the first time for the most part the other gears seem to shift ok but when i hit passing gear it the tack jumps up and i go no where let off gas and im back where i started from let off gas in order to get it to shift could i have junk clogged in the check valve and can i just get rid of it with a piece of high pres hose thanks all for your input and help..
I have the same shifting problems. Replaced solenoids twice and the problem returns in 1000 miles. What did you do to correct this issue?
Old Jun 30, 2011 | 09:11 PM
  #110
djm3452004's Avatar
djm3452004
I'll probably get chided for opening an old post, but I wanted to mention an alternative to the tranny check valve delete that I've worked on over the last few days.
It costs roughly $26 for all the parts at Napa.
(1) Crimp-able Quick-Disconnect Transmission Line Connector (Dodge), Napa P/N: BK 730-4983
(1) Crimp-able Hose End, 3/8" SAE Female Flare, Napa P/N: WH 06U-406
(1) Section of Napa Hydraulic Hose, 8", Napa P/N: WH H24506
(1) 3/8" SAE Male-Male Flare Fitting, Napa P/N: WH 42 X 6
The folks at my local Napa are yahoos, so I didn't trust them crimping the hose ends on there, even though they offer to make hydraulic hoses for you. We have a hydraulic hose crimper at work that worked nicely. The Quick-Disconnect fitting (P/N BK 730-4983) was extremely tight when I pushed it on the hydraulic hose, even before it was crimped down.
Please see the attached photo in the Photobucket link below. I thought it made a neat job of the check-valve delete.
Previously, I had tried to simply cut the check valve off the OEM hose and crimped on the Female 3/8" Flare Hose End (the second P/N listed). This did not work as it leaked transmission fluid from around the edge of the crimp; I think the OEM hose is too flimsy since it is not steel-reinforced. Obviously the double-braided hydraulic hose I used is way-overkill for the pressures this system will see, so perhaps a single-braid hydraulic hose would work as well for this mod.
Anyway, hope this may help someone if you're looking for an alternative to the original mod.
Thanks!
Dave
http://i1030.photobucket.com/albums/...e6-30-2011.jpg
*EDIT* For reference, the info for the Quick Disconnect Tool used to release the transmission lines at the radiator: Advance Auto, P/N AC522, Price: $8
Last edited by djm3452004; Jul 9, 2011 at 07:27 PM. Reason: Adding another piece of info....
