best 46rh shift kit
Old Mar 3, 2009 | 06:06 PM
  #51
95MaroonMonster's Avatar
95MaroonMonster
yea im gonna wait until i have cash to put in the shift kit, and prolly also summer when i have time, along with it a gauge and cooler, get it ready for long trips with the jeep
Old Mar 3, 2009 | 07:01 PM
  #52
xskylinedx's Avatar
xskylinedx
I'm not sure if its the tranny as a whole or if its the fairbanks shift kit, but my truck shifts
HARD! its nice.
Old Mar 6, 2009 | 10:11 AM
  #53
aim4squirrels's Avatar
aim4squirrels
bump, b/c I noticed MonteC was logged in...
See post #49
Old Mar 6, 2009 | 10:01 PM
  #54
transguy37's Avatar
transguy37
Default VB pic
Here is a pic of the E clip that holds the rod.
Old Mar 7, 2009 | 07:45 AM
  #55
aim4squirrels
ahh, a picture's worth a 1000 words.
The sonnax kit comes with a replacement e-clip in case you loose or break the one you had.
I take it by the pic you should remove the manual valve and then pull the clip out. reverse on install.
Old Jul 21, 2012 | 12:34 AM
  #56
TheBeast413's Avatar
TheBeast413
okay, im confused someone help clarify because my solenoid is shot to and I am to replace it, I have a 97 1500 with a 5.2 and I actually tried to take my solenoid out because I saw the refurb post on here hence why I joined ,but anyways my sensor and solenoid were mounted in a bracket next to my filter,.i checked it by hooking.the solenoid up to a 12v source. so my question is what tranny do I have and Ifi buy a b&m replacement for a 46RH will it work with my setup and if not what should I get? hell before I drop $$ lol im not good with trannys.
Old Jul 21, 2012 | 12:44 AM
  #57
gdstock's Avatar
gdstock
How did you determine solenoid was shot? Need a little more info.
Old Jul 21, 2012 | 08:27 AM
  #58
You should have a 46RE in there. The two solenoids on the same bracket are O/D, and TCC. If your trans is an RH model, your check engine light should be on constantly, with various trans codes.
Old Jul 22, 2012 | 08:50 AM
  #59
TheBeast413
when I dropped the pan there were little to no metal shavings, and I have two codes for the governer setup (P1757, P1756) so I kinda assumed that's my issue.
Old Jul 22, 2012 | 08:52 AM
  #60
TheBeast413
I have codes out the ***, I have two governor codes, a TCC code and a 3-4 miss shift code. my truck is a base model of the base mod
