Bigger Oil filter for the 360/318 -Cheap-
Old May 5, 2009 | 06:49 PM
  #91
Cereal Killer's Avatar
Cereal Killer
Yay! Nothing like increasing your oil capacity by two quarts...
Old May 5, 2009 | 06:57 PM
  #92
J415's Avatar
J415
Originally Posted by 95MaroonMonster
no one??
i should make an adapter to make that big mother ****er fit my 318
whats the thread size? I think if you run a remote oil filter and a sandwich adapter, you can mount it anywhere. What are the specs on that filter? what size is the smallest particle it can catch? 10 microns?
Old May 5, 2009 | 09:31 PM
  #93
PurplDodge's Avatar
PurplDodge
no one??
Why? You dont need a filter that big for your pickup truck. A NAPA Gold 1515 filter will do you fine.
Old May 5, 2009 | 10:33 PM
  #94
lv360ram's Avatar
lv360ram
I'm really getting a really good laugh from this thread.
There's the stock filter and then someone finds a bigger one. That's ok but then someone finds an even larger one. Can't stop there - who can find the BIGGEST one! Whoohoo!
I think you guys are eating too much fast food. When you go to the parts store and get a filter do you ask "can I supersize that?"
Don't get offended, lighten up - I just had the "supersize it" thought and wanted to share it.
Now I'm going to finish my triple decker burger and super big gulp.
Old May 5, 2009 | 10:41 PM
  #95
PurplDodge's Avatar
PurplDodge
We like the things in our life to be big. I guess the guy who put the oil filters on our truck didnt have the ***** to use the bigger filter.
Old May 5, 2009 | 11:21 PM
  #96
lv360ram's Avatar
lv360ram
I bought several of the big filters in anticipation of changing the oil in my Durango which has the same engine as my Ram. I used the big filter on my Ram.
Well, I removed the small filter from my D, put oil in the new big filter crawled under my D to install it and duh! it doesn't fit. The big filter hits the frame. So now I have no clean small filter. So, I had to make a special trip to the store to get one.
So, there
There is a reason for the small filter. And I had to find out the hard way, again.
Old May 5, 2009 | 11:28 PM
  #97
95MaroonMonster's Avatar
95MaroonMonster
thats what takes the filter, we fill the filter with oil before installation to keep from starving the engine of oil, thats how big it is
and the 2 fuel filters, hydraulic filter and coolant filter/conditioner are all bigger than our oil filters.
The tractor has a 6 cylinder inline diesel with 355 HP at the PTO, a 10 speed powershift transmission, and a big *** turbo charger hanging off of the exhaust manifold.
Best part, i get to drive it for hours on end at work.
Old May 6, 2009 | 12:11 PM
  #98
mopar1973man's Avatar
mopar1973man
Hey gang... I know I'm a total noob on the gasoline side of the Dodge products... But us Cummins owner use a bypass filter like a frantz Filter or simular to aid in filtering the oil...
I change my TP roll every 3K and change oil and main filter every 10K... Would this apply the same way as what you guy are aiming for?
Here is the manufacture site...
www.wefilterit.com
Old May 6, 2009 | 06:45 PM
  #99
95MaroonMonster
how much did that TP roll filter system cost, id like to get on for my next truck [common rail]
Old May 6, 2009 | 07:18 PM
  #100
Cereal Killer
P-pump pwnz commonrail =p
