Bigger Oil filter for the 360/318 -Cheap-
Old Dec 12, 2009 | 03:10 AM
  #151
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by 1fast2liter
truth be told when was the last time you herd a motor blowing do to the oil used or a filter.
A couple times, actually, when FRAM filters were used. Cardboard junk.
Old Dec 12, 2009 | 11:12 AM
  #152
charlie1935's Avatar
charlie1935
Originally Posted by madmax0r
Hey, check this out.. this would get rid of the limit of filter size because of it hitting our frame...
http://cgi.ebay.com/ebaymotors/NOS-M...021210006r8972
It looks like this:
My 87 5th ave. has that 90 degree mount.
Some have claimed a restriction due to the 90 degree turn of the oil in extreme performance applications.
Old Dec 12, 2009 | 11:18 AM
  #153
J415's Avatar
J415
Originally Posted by 2001Ram
Ok, so what is the best oil filter that money can buy? Motorcraft? Mobil 1? K&N (is currently what I have on now, but you guys have made me question them)
If your gonna use a K&N, you might as well just save a little money and by a Mobil ! from walmart. There manufactured by the same company and cost half as much as the K&N'S. I'm using a Mobil 1 right now but on my next change I'm gonna use a Napa filter.
Old Dec 12, 2009 | 11:26 AM
  #154
cmckenna's Avatar
cmckenna
Originally Posted by PurplDodge
I change mine every 6,000(Royal Purple). I change my tranny fluid every 15,000.
Which Amsoil? There is one that lasts 25,000 miles.
The one I use doesn't have to be changed for 35K miles and, so far, I have over 1000 miles on it and the oil still looks as new as the day I put it in.
Just a quick thought, if people are looking to increase oil capacity, the oil pan can easily be changed out. I know it's easier and cheaper to just place a larger filter in though. Also, although it was mentioned before, thought I would pass along that Amsoil makes a two quart remote oil system that increases the capacity by two quarts.
Old Dec 12, 2009 | 11:28 AM
  #155
cmckenna's Avatar
cmckenna
I had bad luck with K&N. It was too restrictive on my Dodge and my oil pressure went way up using one of their filters.
Old Dec 12, 2009 | 11:54 AM
  #156
Augiedoggy's Avatar
Augiedoggy
Originally Posted by charlie1935
That problem can be solved by going to a remote mounted oil filter.
I installed one of those on my ac vw.... the scary thing with them is worrying one of the hoses will come off.... the solid one like you posted a pic of is nice but testing showed on many of them that they limit flow at higher rpm's...in racing engines its a bad thing
Old Dec 12, 2009 | 11:57 AM
  #157
Augiedoggy's Avatar
Augiedoggy
even though they are made by the same people I believe tests showed they were not made the same....the filter media was different as well as surface area...I agree fram is cheap cardboard crap...and I have to believe when the fibers in the cardboard (or glue) come apart it cant be ideal in the engine...
Old Dec 12, 2009 | 12:07 PM
  #158
cmckenna's Avatar
cmckenna
Ah, I see. They are not the same filter. I was told they were indeed exactly the same by someone on here. Even had a link to some site where, one fella was cutting them open and posting pics of the process as well as the innards.
Interesting to note. Napa gold is wix correct? I think I had seen this mentioned here. However, my memory may be wrong on that one.
Old Dec 12, 2009 | 12:56 PM
  #159
sawtooth's Avatar
sawtooth
Wrong size oil filter!
http://www.2news.tv/news/local/78942972.html
Old Dec 12, 2009 | 01:29 PM
  #160
J415's Avatar
J415
I was just going off of what I read on bobistheoilguy.com He seems to know what he's talking about...And yes, napa gold if wix.
