Bigger Oil filter for the 360/318 -Cheap-
Old Feb 9, 2009 | 05:42 PM
  #41
zman17's Avatar
zman17
Retired Moderator - RIP
Never mind the 90 degree bend, If there is going to be a restriction I'd have to say it's with the mounting bolt.
Old Feb 9, 2009 | 07:15 PM
  #42
aim4squirrels's Avatar
aim4squirrels
Isn't it possible that a larger filter could cause the media to collapse under heavier oil pressures (like running a high volume pump)? Just a thought on why the stock filter is the size that it is.
Old Feb 9, 2009 | 07:36 PM
  #43
Rex-TheDOGG's Avatar
Rex-TheDOGG
High volume pumps don't necessarily mean higher system pressures, but definitely higher flow rates (GPM). I suppose that if the filter bypass was stuck closed, then the filter media could collapse. I think filter size has more to do with how much filter area the engineer can get vs. space allowed and overall cost.
Old Feb 9, 2009 | 08:37 PM
  #44
madmax0r's Avatar
madmax0r
I woudldn't think so, the media is supported by metal.. if the filter is clogged enough to make a difference, it is beyond the point of needing to be changed, I would think
Old Mar 15, 2009 | 10:51 PM
  #45
dodge6's Avatar
dodge6
Default bigger filter
I've used the filter for the v-10 engine on my 1997 5.9l/360 since it was new.
Purlator use to list it for heavy duty service for the 5.9l but stopped showing it in their application book. WIX filters web site lists all the thread and gasket sizes for their filters as well as bypass and pressure ratings. You can find a filter that works for you and either buy WIX or use their number to cross ref to the brand you want.
WIX 51452 thread 3/4-16 L=5.178" OD 3.66", bypass 8-11 psi anti drain back, burst 415 psi, max flow 7-9 gpm, nom. micron rating 19
Old Mar 26, 2009 | 12:47 PM
  #46
PurplDodge's Avatar
PurplDodge
Cross Refrence-
K&N: HP-3001
Napa Gold: 1515
WIX: 51515
Motorcraft: FL-1A
Mobil 1 Extended Performance: M-301
Frap: PH8A
Purolator: L30001
Amsoil: EAO15
AC Delco: PF2
Baldwin: B2
Bosch: 3500 or 72102
Old Mar 26, 2009 | 01:20 PM
  #47
tsparr's Avatar
tsparr
I work at an auto parts store that sells fram, wix, k&n and Defense Line (cheaper Fram without the orange color and name) and we get a lot of racers and wheelers in that swear by wix. its what i use on my rig and i've never had a problem with it. fram is absolute garbage though. we sell fram and defense line to soccer moms and shops that want the absolute cheapest filters. one of our customers set a land speed record in the salt flats and he uses royal purple and wix. thats enough proof for me.
Old Mar 26, 2009 | 10:19 PM
  #48
TheePlaymaker's Avatar
TheePlaymaker
you guys notice any difference in oil pressure with the bigger filter or need to add more oil...mine already goes a little over the full mark when i put 6 quarts in so im guessing it wouldn't be a problem for me
Old Mar 28, 2009 | 08:22 PM
  #49
charlie1935's Avatar
charlie1935
I saw no difference in pressure. Takes approximately 1/2 quart more oil.
Old Mar 28, 2009 | 08:46 PM
  #50
lv360ram's Avatar
lv360ram
Something just doesn't feel right about this. But it fits.
And my hard core Ford friend had a jaw dropping experience when he saw it.
