Forced Induction
Old 02-08-2009 | 04:59 PM
BlueRamSport's Avatar
BlueRamSport
Default Forced Induction
Anybody make supercharger or turbocharger setups for 2nd gen Rams with gas engines? (360)
Old 02-08-2009 | 05:38 PM
lastrights's Avatar
lastrights
i know procharger makes em. you can put it on a stock motor , you get 50-65% more power , its also intercooled for cooler air. i think one of the indy ram guys has one on his truck
Old 02-08-2009 | 06:41 PM
dodgeboy7's Avatar
dodgeboy7
yea pro chager makes you if you ever watch TRUCK! on tv they did one on a 2gen dodge (The little red express) i think and i think indyram has the 408 prochager i dont know if he done yet though
Old 02-09-2009 | 12:13 AM
RM_Indy's Avatar
RM_Indy
Procharger makes kits(complete in every detail) for Dodge Rams. KRC Performance sells them plus Vortech kits they put together as well. Couple other places you can get them online(see Procharger link below for other suppliers). No turbo kits available, if you want a turbo your talking custom which will cost a fair bit more than a supercharger kit.
Base Procharger kit starts at 4600 for satin finish P-1SC, 2core air to air intercooler and digital fmu (variable rate)which should give 8-9psi. Guys Ive talked to that started stock with the base kit saw 55%rwhp gains.(if well maintained/good compression) I detuned, removed the ramairbox and under drived the D-1SC (w/3core) on my mild 360. 7psi gave me about 49% increase above what I had prior to detuning.
KRC only shows the larger kit now, call them if you want the base kit. They supply the D-1SC headunit and rated it 10-14psi and supply stronger headgaskets and 2core intercooler ATI/Procharger rate the D-1 for 10-12psi. Not sure, KRC may supply a different pulley or is being optimistic
Looks like a typo on KRCs Procharger kit. They say $6500 on the main page but if you click "add to cart" it shows $5k.
http://www.procharger.com/TRUCK_SUV/truck_suv.shtml
http://www.krcperformance.com/krc/in...d=38&Itemid=26
My planned all forged/mild 408, ended up radical. Needed to replace everything I was using prior, so last 2yrs been collecting parts and painting, polishing & powdercoating everything I could under the body that I missed first time around. Here's what it looked like with the mild 360 w/polished D-1SC & 3core a/a intercooler.
Old 02-09-2009 | 02:10 AM
360dodgeram360's Avatar
360dodgeram360
i was wanting a roots type supercharger because i like the way they look and imagine they would be much cheaper than the turbine or centrifical styled procharger with intercooler. can anyone tell me what all i would need for a roots supercharger setup, how much it would cost, and how much power it would add?
Old 02-09-2009 | 02:47 AM
l_teddy10's Avatar
l_teddy10
You have a sick truck.
That is badass.
Old 02-09-2009 | 09:16 AM
xskylinedx's Avatar
xskylinedx
Kenne Bell made a twin screw, which is better than roots in my opinion, but you would have
to find it used due to them not making the kit anymore.
Old 02-09-2009 | 10:21 AM
iwhitne's Avatar
iwhitne
get a leaf blower! lol
Old 02-09-2009 | 11:22 AM
talon6's Avatar
talon6
in all the listings for the prochargers, it says nothing about 02 rams. i wonder if the ones for the 01 rams will work? mine is still the 5.9 with a 7 rib. but it is a 3rd gen.
supercharger is in my future. i have done enough research to know that if you buy one, you should upgrade to the 3 core intercooler. which i would.
Old 02-09-2009 | 12:14 PM
talon6's Avatar
talon6
this is the kit that i want. when i get ready i will contact procharger to make sur it will work on my truck. but i just cannt think of a reason why it wouldnt.
http://www.myride.com/vehicle-partsd...00F1Z5E0#parts
Quick Reply: Forced Induction
