check valves for wild vents
Old Jun 30, 2010 | 04:20 PM
  #101
revvinram's Avatar
revvinram
Well I went ahead and installed the new check valve, the one by "the intake was bad" with all new rubber vacuuum line, also replaced the hose that goes from the intake to the PCV valve all is well now!! It seems to have more power for some odd reason..
Sheriff thanks again for that part #.. Is that the same valve thats closer to the firewall also?
Old Jun 30, 2010 | 06:56 PM
  #102
Sheriff420's Avatar
Sheriff420
Awesome.
Yep, same valve.
Old Jun 30, 2010 | 07:36 PM
  #103
revvinram's Avatar
revvinram
Cool, I'm pickin up a spare.. I can't find the one by the cruise control..
Old Jul 1, 2010 | 01:21 AM
  #104
Sheriff420's Avatar
Sheriff420
There isn't one. The cruise control vacuum line goes from the passenger side of the manifold (splits off next to the check valve) and goes up through a clip on the top radiator hose then down to the cruise control servo under the battery.
You should get a mirror and check out that servo for signs of corrosion from battery acid, it's the unit that is directly under the battery with a vacuum line connected to it and a few guys have had leaky batteries eat holes in them.
Old Jul 1, 2010 | 06:44 PM
  #105
revvinram's Avatar
revvinram
Thanks, but I don't have no corrosion on the battery tray or the servo, even all the plastic lines were in real good condition.. Thank you for the heads up..
Old Aug 28, 2010 | 03:04 PM
  #106
dodgehoodup's Avatar
dodgehoodup
Great thread!
Old Aug 28, 2010 | 03:11 PM
  #107
zman17's Avatar
zman17
Retired Moderator - RIP
Very long, but yes it is.
Old Sep 11, 2010 | 05:09 PM
  #108
mnewbolds's Avatar
mnewbolds
This Wild Vent issue has been driving me nuts all summer! Wish I would've found this earlier. Thanks for all the info guys and I will be at the dealer on Monday to pick up my new cv's. More Power you say..? HELL YEAH!
Old Sep 28, 2010 | 02:09 PM
  #109
gerald137's Avatar
gerald137
Default Thanks
After reading this I looked and my vac line had broke going to my Cruise servo, was causing wild vents nd no cruise. Repaired and good as new.
Old Sep 28, 2010 | 03:09 PM
  #110
Sheriff420's Avatar
Sheriff420
It's great when it turns out to be a simple fix.
