check valves for wild vents
Old Sep 24, 2013 | 12:56 PM
  #201
RareColorRam1995's Avatar
RareColorRam1995
Originally Posted by Ramman18
Mopar has discontinued these check valves! Fear not, though, since Napa now carries them! Echlin part and they are now like $12.
I just ordered 2 of them from the dealership here..o.O
Also, I just replaced my PCV valve, the PCV valve tube, and checked both of the check valves mentioned in this thread. I could blow through both of them only 1 way. I assume they're both fine. Cruise control line is fine going to the servo as well.
Old Sep 25, 2013 | 11:18 AM
  #202
Ramman18's Avatar
Ramman18
I'm sure dealerships still have some in stock. Mine here is a Lithia Dodge and they looked and looked then the manager came over and said the part number changed and it is now discontinued. Went to Napa and the kid found exactly what I needed.
Old Sep 26, 2013 | 06:26 PM
  #203
FrankTank's Avatar
FrankTank
What is the part number that you got at Napa? Have you tried it yet?
Old Sep 26, 2013 | 10:44 PM
  #204
Spillage's Avatar
Spillage
I saw some generic vacuum check valves at AAP a few weeks back... I'll have to check the I/O size to see if they'll fit.
Old Sep 27, 2013 | 12:17 PM
  #205
Ramman18's Avatar
Ramman18
All the receipt says is 2-939 but I think I may still have the little box it came in. It looks exactly like the mopar part right down to the stamping on it. It works great.
Old Dec 10, 2013 | 05:15 PM
  #206
goB1Gred ram's Avatar
goB1Gred ram
Originally Posted by ryker
I've got the same issue. I checked my topside check valve and it holds a vacuum. So I didn't buy a new one. No cruise control either. But I do have 4x4.
I have the same issue, no vent control no cruise control but I do have 4wd. Help.
Old Dec 11, 2013 | 11:45 AM
  #207
Ramman18's Avatar
Ramman18
When I tested both valves, they seemed to work. So I put the new one on anyway and fixed the problem. Vents issues are the valves or lines by the passenger side, cruise is the line going under the battery and the servo.
Old Dec 11, 2013 | 11:53 AM
  #208
Cruise control has it's own vacuum line, they like to crack/break/get eaten under the battery, at the cruise servo. (and the servo itself tends to get eaten by battery acid as well.)
Old Dec 12, 2013 | 10:27 AM
  #209
ranger36's Avatar
ranger36
My wild vents ended up being an actuator behind the glove box that controls a door when selecting max a/c or just a/c. The actuator was leaking so it didn't hold vacuum.
Old Jan 28, 2014 | 10:20 PM
  #210
RareColorRam1995
The NAPA part # is 2-939. It's EXACTLY like the factory check valve. Sucks that it is $12.99 though
